View Poll Results: Cylinder 7 fails first because the.....
Intake leans out that cylinder
48.98%
Fuel rail doesn't supply fuel equally
2.04%
Coolant flow inadequate
30.61%
Engine firing order
0%
I have no idea......
18.37%
Voters: 49. You may not vote on this poll
Why does number 7 fail first (tech only)
Old Jul 22, 2008 | 05:26 PM
  #31
Wilde Racing's Avatar
How do I change this text
Originally Posted by fossil
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer".
LMAO, I guess we are all "Do-it-yourselfers".....
Im not saying this is the problems why #7 piston goes bad. Just shedding some light on some problems we see at the dealership with fuel delivery.
Thank you for the information.... I wasn't a believer of the fuel problem until now...
I think Thunder hit it... all of the above.....
Old Jul 22, 2008 | 05:50 PM
  #32
fossil's Avatar
11 Second Club
When I ran my stock 6.0L with the truck intake #7 and #8 spark plugs was by far the the cleaner plug (white) when I would check them. On my L92/L76 set up #7 and #8 sparkplugs have some of the best color (lt tan), while #3 and #4 are my cleanest sparkplugs (real lt tan)? Go figure?
Old Jul 22, 2008 | 09:40 PM
  #33
Stoichiometric's Avatar
Say you are spraying methanol and #7 is getting the most airflow. Would the truck intake keep the methanol atomized enough to deliver the right proportion to #7? Or is the AFR drop you see on the wideband coming from the other cylinders?
Old Jul 23, 2008 | 10:26 AM
  #34
billyjo's Avatar
Originally Posted by lsxmalibu
I have the factory temp sender in the drivers front, and an electric temp gauge in the passenger rear. normal driving the rear gauge is 10+ degrees hotter, but when I run it through the gears, full throttle...the rear spikes over 200 and the front sender reads 170........as soon as I let off the gas the rear levels back out..
That is interesting, I also have a Autometer temp gauge on the passenger side along with the factory one installed on the drivers side. My Blazer still has the stock thermostat in it but I am running a much larger aluminum radiator and oil cooler with the electric fans.
When I'm driving down the road @ cruising speeds and logging with EFI Live the computer always reads around 192 F and the Autometer gauge reads around 175 F. I've never watched it while I was under full throttle but when I sit in traffic and it starts to warm up the computer reads around 202 F and the Autometer reads around 200 F.
I wondered if this difference from side to side was because the way the coolant entered the engine.
Just food for thought
Old Jul 23, 2008 | 02:52 PM
  #35
Doobie's Avatar
Running a stock truck intake my plugs all looked the same (light tan spot on insulator next to intake valve) but #7 insulator was pure white. This plug reading indicates a lean cylinder. After installing a Radix with their manifold and brand new plugs I rechecked all plugs at 1K. #7 insulator was still pure white and the rest looked the same as with stock manifold. This leads me to believe there is a cooling issue with #7 and it's running hotter than the rest. Would higher temps around #7 cause this plug to indicate a lean burn? I originally thought #7 plug indicating lean may have been caused by air flow through stock manifold but this disproves that theory for me. I'm Going to try a 170*~180* T-stat for cooler engine temps. and maybe better piece of mind. I want to minimize my chances of #7 under boost.
1989k1500
Nov 2, 2015 05:16 AM
nabozny21
Oct 17, 2015 07:47 PM
KleanKustoms
Sep 30, 2015 05:07 PM
1989k1500
Sep 29, 2015 10:53 AM
Slammed silverado
Sep 28, 2015 06:14 PM
