Why does my cat sound like this?
Old Mar 26, 2007 | 07:52 PM
negativeswitches's Avatar
Originally Posted by Quik
nope!!! tubes on cats are for air pumps. its so you can have air pumped into a cat to help cool it so it doesnt heat up and melt and get clogged. cheap cats have those along with older stock production ones
actually this is a common misconception of the cat converter, the wir pump was designed to lights the cat converter up with o(oxygen) so it can properly ignite the unit to convert h2(hydrocarbons) into h2o (water)
the airpump was made to kick on when the rear o2 sensor was not reading "x%" leaner than the front o2 sensor
the funny thing about it is you need a reaction to affix the molocules together, requireing energy, thus creating heat making the cat hotter
kind of ironic eh?
-erik
Old Mar 26, 2007 | 07:54 PM
oh yeah your cat is busted get a new one before the chunk bouncing around gets lodged in there sideways creating REALLY high backpressure causeing a driveability problem (this happened to my 98 s-10)
-Erik
Old Mar 26, 2007 | 08:09 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Well sweet. They are maganaflow cats. Been on just a few months. Straight pipe maybe. I'll have to look around. I think I may clamp both ends so I can pull them without having to weld.
BTW this started after I hit some crap in the road pretty hard while in Atlanta. Also scrubbed up the chrome and tore a hole in the tire. New tire...only $500
Old Mar 26, 2007 | 08:12 PM
depending on where you live most places that have emissions require they be welded/sealed atleast 18" on either end of the converters
Old Mar 26, 2007 | 08:29 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
all that shitty tuning of yours killed them
Old Mar 26, 2007 | 08:52 PM
1SlowHoe's Avatar
I havent tuned it for the cam yet. Thats why I'm running 14.2 cruising and 10.4 at wot
Old Mar 26, 2007 | 09:21 PM
1SlowHoe's Avatar
And...does it matter if it's on backwards? I'm not using the air injection so....it doesnt really matter right?
I dont have emmisions testing so gutting them I guess would be an easy fix.
Old Mar 26, 2007 | 09:23 PM
yeah it makes a difference if they are on backwards (wont be effective)
you could gut them if you dont care about the environment
-Erik
Old Mar 29, 2007 | 11:22 PM
1SlowHoe's Avatar
-Erik
I could drive a Prius as well but, I don't.
So,.....if I gut them, what code do I need to turn off in the tune so the O2's don't go crazy?
Where exactly do I go in EFI live to change code reponses?
Old Mar 30, 2007 | 12:21 AM
nonnieselman's Avatar
What about look for some cheap stockers?
And i got one question for ya man.....
Um.... Whats this stuff? Can you get it from WallyWOrld?
