Why did this happen w/ the UPD?
Old Aug 30, 2003 | 10:18 AM
SmokinLM7's Avatar
Default Why did this happen w/ the UPD?
After three long weeks,I finally got my UPD and installed it 3 days ago. I can hear more air getting into the engine, but my truck now shifts sooner. I had the HPP3 set at +3 for 1-2 shift and +10 for 2-3 and it was shifting at about 6000 rpm at WOT. After I installed the UPD it now shifts at about 5700 rpm, which made the truck a tad slower. What caused my shift points to drop? What should I do to get it back to shifting at 6000 rpm?
Old Aug 30, 2003 | 10:37 AM
YellowChevy4.8's Avatar
Default Re: Why did this happen w/ the UPD?
I don't know why the UPD would do that, but set your shift points to +4 on the 1-2 and +12 on the 2-3 and then set ur rev limiter on 6200 rpms. I've had mine set this way since I got it and it shifts at ~6k for the 1-2 shift and then at 6K for the 2-3 shift.
Old Aug 30, 2003 | 12:48 PM
GREGGO's Avatar
Kinda wierd. Did you disconnect the battery? I guess you could have lost something in the PCM if you did that, but I don't see why.
Old Aug 30, 2003 | 02:15 PM
454SuperSport's Avatar
make sure you don't have any air leaks in the intake. my intake came loose at the throttle body once and it shifted really wierd.
Old Aug 30, 2003 | 02:59 PM
Flyer's Avatar
For some reason, which I'm not to sure about, the MAF has a lot to do with the shifting of the transmission, including firmness and shift points.
Old Aug 30, 2003 | 03:14 PM
FILE's Avatar
I had something very similar happened to me with my 01. When I initialy installed my HPP3, I was shifting @ about 6k. However, after several months, I was shifting several 100's rpm's lower.
Old Aug 30, 2003 | 07:59 PM
Flyer's Avatar
On a side note .. I don't see how shifting at 6k would help perfomance unless you were blown or cammed or some other type of engine mod (not bolt on).
The stock cam shuts down quick at about 5300-5400. After that, it's just raising rpm's for the shift.
Old Sep 2, 2003 | 12:27 AM
SmokinLM7's Avatar
Ok, I changed my shift points and rev limiter this morning from +3 & +10 to +4 & +12 and rev limit up to 6200 rpms and my truck will still shift at around 5700 rpm. Could this be TM? Timing? Running lean? So what should I do now?
Old Sep 2, 2003 | 10:10 AM
BigKID's Avatar
Are you sure you installed your MAFS back in the correct direction? Is the truck running bad? If it is seeing a problem with the meter, it could be in limp mode.
Choda
Jun 5, 2025 06:43 PM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
blackedoutchevy22
Oct 1, 2015 08:07 PM
KleanKustoms
Sep 30, 2015 05:07 PM
Cammed4ever
Sep 30, 2015 03:38 PM
