Who's running the VHP 44 cam?
well you 2 have about sold me:-P
Quiet: which tune do you have for this cam? The 1 or 2 tune off the crane?
the tuner woke mine up with the stock cam! Cant wait to see what it does with the cam lol.. I know the perf 1 and 2 raises shift points, so do you select the enhance trans shifts for another 300rpms also?
hypertech isnt really gonna do anything but raise the shift points to benefit up top with the cams...
Crane/VHP has built in cam tunes for certain cams.. you can raise the idle with the crane tuner also Basicially that tuner kept in mind what most of us wanted to do and what we wanted.. Hypertech just lets you play with shift points and supposedly helped tune for certain types of gas. I never saw a difference in my 98 TA with the hypertech, but this crane tuner really.. realllly woke the truck up at part throttle.. took the lady for a ride tonight and we asked what the heck i had done... LMAO
thanks a bunch for the reply
im just waiting for a good VHP GP hopefully now
Any idea what the shift points are with the cam 1 vs 2 settings also?
I have a friend who tried the Hypertech with this cam and it doesn't run nearly as good as mine does with the Crane tuner.
quiet, i take you arent using the enhance shift points option? I think that gives another 300rpms right? Would that make it 6200 if you use both? I dont know how they work in combo with each other...
also, something else with the crane.. when you go back to change something, do you have to do everything over again? So i select mid grade fuel, the next time I program it says stock fuel or something. I didnt know if i could just select no and skip and go to which ones I needed to edit or not.... i guess that makes sense lol
Yes, I have been able to only change one thing, but there isn't much difference in time if you change one or change all. It seems the first programming from stock to custom takes 4-5 minutes. After that, the changes only seem to take about 1minute to may be 90 seconds.
Since I am new to the site (not meaning to hijack this thread either), but is VHP, Vinci Hi Performance??? I figure that it is,. but just wanting to make sure as I am wanting to make a cam purhcase as well, and Vinci is working on a GP, and looking at this thread VHP makes a killer cam that you guys are happy with. Doesn't VHP have their cams ground through Crane??
lxcoupe
07-27-2015 08:19 PM
