Who's got a 'Burban / 'Hoe/ 'HD with 2 piston rear discs?
I was spying at my single pistons calipers and well it looks like the larger two piston rear calipers will fit!
Anyway, I just need a rough measurment on the distance between the two bolts that hold the caliper on. Just gotta climb on the ground and bust out a tape measure.
I figure if I can utilize the two piston calipers with stainless lines all around (I found someone to make those DOT legal, $40 a line) and cross drilled rotors (yep found those too @ $160 pair), I may be able to stop nicely.
Thanks!
Thanks!
SLOPONY
20
Oct 18, 2016 06:05 AM
lycominghunter
Aug 15, 2015 12:26 PM
mrgrim
Jul 8, 2015 08:12 AM
