Who I Know Someone Took 5.3 And Went To A 377 Cir 370ci
Old Nov 27, 2005 | 07:58 AM
litreddevil's Avatar
Banned
Default Who I Know Someone Took 5.3 And Went To A 377 Cir 370ci
I Know Someone Did It Just Don't Remmber Who Just Want To Know What It Takes.did U Have To Resleve The Block,r Did U Just Bored The Block.
Old Nov 27, 2005 | 08:24 PM
Banned
I Know Someone Knows Who Did This.
Old Nov 28, 2005 | 02:59 AM
PappyDan's Avatar
Tribe Shaman
the 5.3 can be bored out to a 5.7 for 343 ci, all you would need is just the LS 5.7 pistons.
the 5.3 / 5.7 / 6.0 all use the same crank and rod length. only the 4.8 is shorter.
with the 5.3 punched out to a 5.7 and use a aftermarket 4.0 inch crank you will come close to a small block 383.
add the 6.0 heads, a good cam and you will have a monster on your hands that will kill a stock 4L60e in a few runs.
Old Nov 28, 2005 | 08:08 AM
01Blackerado's Avatar
If it's only bored to the 5.7 liter specs then the 4" crank gives you the 377 you're looking for!!! 5.3 can be bored safely to 3.903 and with the 4" crank that makes you a 383!! It's the exact same thing I did!! Which will be installed soon by the way
Old Nov 28, 2005 | 11:38 AM
Big10Fan's Avatar
Why the heck do you capitalize every first letter of every word? I feel like I'm reading a ransom note or something.
Old Nov 28, 2005 | 12:40 PM
leochevy2001's Avatar
explain that again please
5.7 specs w/ 4" crank = 377cu
5.3 bored to 3.903 w/ 4" crank = 383cu
am i missing something? what are the 5.7 specs?
Old Nov 28, 2005 | 01:41 PM
treyZ28's Avatar
I was thinking book title.
Old Nov 28, 2005 | 04:30 PM
BooBsRGR8's Avatar
The stock bore on an 5.7 LS1 is 3.898 with a 4.000 stroke you only get 382ci Bored to 3.903 with 4.000 stroke you get 383ci. Stock 5.3 bore is 3.779 with 4.000 crank gives you 359ci.
Old Nov 28, 2005 | 04:36 PM
BooBsRGR8's Avatar
Oh and no it doesn't need to be resleeved to be bored to 3.903, anything bigger and it does.
Old Nov 28, 2005 | 04:50 PM
yyyyyyyyep
