Who has this exhaust?
Old Mar 19, 2007 | 05:14 PM
01midnightss's Avatar
Default Who has this exhaust?
Guys im wanting to add a bada** sounding exhaust on my truck and im kind've on a budget so I found this exhaust by flowmaster http://www.autoanything.com/exhausts...0A2491723.aspx and was wondering if any of you have this on your truck and if so could you post up some pics. I like the look of the duel outlet coming out one side and would like to see how this would look on a Silverado. Also does this come out behind the back tires or in front of them? And if you do have this system how do you like it and/or if you had to do it over again would you get a different one and why. Thanks.
-Ben
Old Mar 19, 2007 | 08:02 PM
I've had this exhaust setup on my truck for about 8 months now. I like it alot, and it is definitely louder than the one I had previously, which had dual out the back. It was a little easier to install than one that goes over the axle, but due to the awkward bend after the muffler, the tips were a little difficult to get on. There are only 2 problems that I have had with this system.
1. Rocks and other debris has a tendency to get thrown up by the wheels and increases the risk of dinging the tips. I've heard it a couple of times.
2. Last weekend I was going to dinner, and my girlfriend heard a grinding noise, then I heard the exhaust get louder at about the same time. We pulled over and the connection before the muffler had come loose. I could never get this connection tight enough, and the muffler/tips would rotate towards the ground. Total movement, about 3 inches. Never dragged, but it was a little unnerving. My advice would be to get someone to at least tack weld the connections, if not a full bead around the pipe.
Overall, I really like the system. I had a neighbor that would park his van next to my passenger side, and every morning at 6:00 I would set off his alarm when I started up. After about a week of this, he changed his parking lot.
Now, to answer your remaining question:
The exhaust exits right before the rear tire.
I will post a pic tomorrow on my webshots folder when I get a chance. Probably in the evening.
Old Mar 19, 2007 | 08:42 PM
Hey, thanks a lot for the reply. Also if you have one could you post a sound clip up as well. And did you notice any power gains/loss?
Old Mar 19, 2007 | 10:31 PM
Quik's Avatar
5 year bitches!
heres that exhaust with a 11.1 6.0 and ORY
http://s92.photobucket.com/albums/l3...t=S5030332.flv
beastmode now has my old catback
Old Mar 20, 2007 | 02:15 AM
99Silverado5.3's Avatar
When I think of badass exhaust, I think LT headers with true dual bullet mufflers.
Old Mar 20, 2007 | 06:13 AM
beastmode's Avatar
Import Moderator
ya check out my exhaust clip on my sig, like Quik said this is his old catback i dunno how long he had it for before i picked it up off him but ive had it for probably 2-3 months now and if something ever happens to this one (rust) im def buyin another one
Old Mar 20, 2007 | 11:48 AM
I hear ya man. Thats the setup I had on my Camaro. LT's, TSP True dual setup dumped right before the axle through bullet mufflers, and a large cam. I miss that sound. Dont really want to put that kind of money into the truck like I had in the car. So I figured the FM catback was one of the deepest and best sounding for the price, plus I like the way it exits right before the rear tire.
"Beastmode" and "Quik" your trucks sound good! What did you run on that pass Quik?
Old Mar 20, 2007 | 11:53 AM
Quik's Avatar
5 year bitches!
heres an idle clip of that exhaust and the old motor setup
http://videos.streetfire.net/video/d...400b8c78a3.htm
i think that pass was 12.7s dont remember much
Old Mar 20, 2007 | 04:24 PM
One last question guys, will this system fit on my truck? Because it only has it listed as: Fits the 2/4wd, 119" Wheelbase, Standard Cab Short Bed, 1/2Ton, 4.8/5.3L Engine. My truck in 4wd, dont know the wheelbase length and its a ext. cab with the 6.0L. So will this system work on mine?
Old Mar 21, 2007 | 09:01 AM
Help me out guys if this will work on my truck. Really want to get it ordered, but dont know if it will bolt up to the 6.0 w/ext. cab.
