Who has changed lifters?
Old Feb 10, 2005 | 07:37 PM
greentahoe's Avatar
Default Who has changed lifters?
A friend of mine is appalled to hear that I didnt change my lifters with the cam especially with the 80K the truck has on it. Have any of you changed lifters? Is it necessary in my case? I may have to keep the 5.3 for a while as other things have come up.
Old Feb 10, 2005 | 08:35 PM
SimpleManLance's Avatar
i was wondering the same thing. is it really necessary? how do you keep the lifters up while changing a cam, with out taking the heads off. i plan on doing a cammed 6L and i was just going to take the heads off and replace the lifters.
Old Feb 10, 2005 | 09:06 PM
I've never heard of anyone changing the stock lifters on a cam only ls1. All you do is insert some 5/16" rods into the two holes on the front of the block before you pull the old cam out. There is a good write up here: www.ls1howto.com
Old Feb 10, 2005 | 09:35 PM
The stock hydralic roller lifters are ok unless you are going with dual valvesprings with a high seat pressure.
Old Feb 10, 2005 | 09:42 PM
budhayes3's Avatar
PT's Slowest Truck
You never want to reuse flat tappet lifters when changing a cam, rollers like ours aren't a problem though. They don't "wear in" the way that the flat tappets do. Most of the guys here who did cam only swaps have re-used the stock lifters, myself included.
lsxperformance
Apr 20, 2016 12:17 AM
superchomper2003
Aug 26, 2015 09:39 AM
Jake75
Aug 5, 2015 01:26 PM
lxcoupe
Jul 30, 2015 02:42 PM
Suburban2500
Jul 19, 2015 04:50 PM
