WHO ALL HAS DONE A 5.3 CAM SWAP
Old Jul 17, 2002 | 10:44 AM
RED2K's Avatar
Default WHO ALL HAS DONE A 5.3 CAM SWAP
I NEED HELP PICKING A CAM. IF YOU HAVE DONE A CAM SWAP TELL ME WHAT CAM AND SPECS AND IF YOU LIKE OR NOT. I WANT ONE WITH SOME WHAT OF A LOPE BUT CAN STILL PULL SOMETHING HEAVY ONCE AND A WHILE. GONNA DO SOME PUTER TUNING AND HAVE ALREADY MADE SOME TOHER MODS. THANKS IN ADVANCE.
Old Jul 17, 2002 | 10:57 AM
oxidizr's Avatar
Moderator / Sponsor
Default Re: WHO ALL HAS DONE A 5.3 CAM SWAP
SSHOTRODS has done a small Comp cam swap with some minor head work. His results were good for overall drivability and would reatain much of your lowend torque while raising HP. If you desire to make more peak power (more duration and/or tighter LSA cams) the powerband tends to shift higher and towing will be more an issue. You will get the "cammy" lope you are looking for this way but low speed drivability will suffer.
Richard
Old Jul 17, 2002 | 11:17 AM
RED2K's Avatar
LOOKED AT THE SIGHT AND THAT A DAMN NICE TRUCK..MINE LOOKS ALOT LIKE THAT ON THE OUTSIDE{ LIKE TWINKIES.LOL} NOW I WISH IT HAD AS MANY MODS AS HIS. WHAT IS THE 3RD GEAR TRANS PACK? I KNOW I SOUND LIKE A DUMMY ON HEAR BUT I HAVE NEVER MESSED WITH THESE NEW TRUCKS, JUST OLD SIMPLE ONES.
Old Jul 17, 2002 | 01:45 PM
oxidizr's Avatar
Moderator / Sponsor
You may want to shoot John an e-mail. I know he has some audio on his site but I don't think he has any with the H/C set-up. Knowing John, he will probally post some new audio soon.
I don't think that his cam would have a very "lopey" idle, definately not stock but the duration and LSA would suggest this cam would be very mild.
Stock tuning is OK but can be improved upon as it is nowhere near optimal with the improved head flow and the cam.
Richard
Old Jul 17, 2002 | 02:04 PM
BigKID's Avatar
I thought he (SSHOTRODS) might chime in to answer the questions, but since he is not I will answer them for yall. He is a buddy of mine and i help him out with his mods.
After driving his truck (and racing him) there is a small loss of low end torque but the 3500+ rpm hp more than makes up for it. You can really feel the truck pickup after 4K and will pull all the way to the 6100 shift. I havent riden in it while he was spraying yet but I bet it is a real kick in the pants with the new cam because of the split duration. The cam has a small lope to it but is really only noticeable to the trained ear. To the adverage joe it just sounds like he has a different sounding exhaust. Tunning is not required for this cam but I believe he has a few more ponies to gain if he did get some custom tunning done. All in all I think this is a good cam for the 5.3 trucks if you are looking for a higher performace truck rather than a tow truck.
Old Jul 17, 2002 | 03:08 PM
oxidizr's Avatar
Moderator / Sponsor
Thanks for the info BIGKID. Has John got the converter put in yet or made any passes with the existing combo?
Richard
Old Jul 17, 2002 | 03:12 PM
Is SSHOTRODS a SPONSOR here if so i can't find it?
________
Kitchen Measures
Old Jul 17, 2002 | 03:30 PM
RED2K's Avatar
WITH THIS CAM WILL I HAVE TO CHANGE CONVERTERS? I HAVE 3.73'S NOW. I WILL TOW A RACECAR THAT IS 2600LBS BY IT SELF. ONLY ONCE IN A WHILE.I WOULD LIKE TO BEAT A MUSTANG GT. I AM GETTING HEADERS, TUNING, 80MM T.B. . I BOUGHT A AIR TEMP. SENS-RELOCATER FROM JET BUT I NEED TO KNOW THE BEST PLACE TO PUT IT. I DONT WANT TO RUN SPRAY OR A SUPERCHARGER. WHAT ARE SOME FREE MODS I CAN DO. I HAVE A STOCK K&N WITH A HOMEMADE RAM AIR.
Old Jul 17, 2002 | 03:51 PM
oxidizr's Avatar
Moderator / Sponsor
Hyde:
He's just memeber with a lot of info on truck performance goodies (from s-10 to c/k 1500 tech.) He doesn't sell anything.
Red2k:
You don't NEED a converter with this cam but it would produce better ET with one. I would be curious to see this cam with a few extra degrees of advance ground in to help those searching for a good torque cam.
Old Jul 17, 2002 | 03:57 PM
RED2K's Avatar
FEW EXTRA DEGREES OF TIMING FROM THE AIR TEMP RELO? WOULD A Z06 CAM PERFORM BETTER
