Whipple boost at idle?
Old Jul 2, 2005 | 04:01 PM
Will's Avatar
Default Whipple boost at idle?
Ok guys I have taken my truck to a transmission specialist and he is telling me that I have 2psi of boost at idle going into the transmission. I am running the old style whipple with the 2 belt setup. I am just curious what could cause it to be giving this much boost at idle? If I am looking at my boost gauge in the truck it shows vaccum. I have the boost gauge hooked into the vaccum line that comes off the intake and not on the brake booster. Anyone have any ideas as to how I can get 2psi of boost into the transmission at idle? BTW, this transmission is a vaccum modulated built transmission.
Old Jul 3, 2005 | 11:39 AM
rosscob's Avatar
That's wierd!
Old Jul 3, 2005 | 11:47 AM
parish8's Avatar
single digit dreamer
if your gauge is showing vacume then you do not have boost going into the tranny at idle. i have a vacume modulated tranny too and chuck told me it was very important to not put boost into that line going to the transmission. i think it has the ability to raise line presures over what is safe. he sent me a check valve that prevent boost from going to the tranny.
Old Jul 3, 2005 | 01:05 PM
Will's Avatar
I think he put the same check valve on mine too. I am not sure though. Is it a little golden device that goes from the boost line into the transmission?
Old Jul 3, 2005 | 01:29 PM
parish8's Avatar
yes, you need to make sure that valve is put in the right direction.
Old Jul 3, 2005 | 03:13 PM
Will's Avatar
Even if it is in the right direction, should I really be getting 2psi of boost at idle anywhere?
Old Jul 3, 2005 | 03:17 PM
parish8's Avatar
if you gauge shows vacume then you are not seeing boost.
Old Jul 3, 2005 | 08:36 PM
Will's Avatar
No matter where the boost hose is tapped into?
Old Jul 3, 2005 | 08:45 PM
parish8's Avatar
you said the gauge is tied into the intake. anyplace on the intake is a good place to get a reading. there are some vacume lines under the whipple that you dont want to tie onto.
Old Jul 4, 2005 | 12:13 AM
BigTex's Avatar
Lets see will- you have money to take your truck to a transmission specialist, but you still won't pay me for the motor I sold you a FULL YEAR AGO?
I suggest no one give this thief any more help. Also, no one needs to buy or sell anything to William Nelson from Dallas. He's a liar and a thief. Check his many ebay accounts if you want more proof. Scamming people out of satellite equipment. He's also in a lawsuit for scamming a fellow Tech member from Arizona out of a motor last year. POS!
