wheres my coolant going?
Old Jun 14, 2010 | 11:17 AM
ryanthorsen's Avatar
Default wheres my coolant going?
gotta 03 silverado, 5.3 with a few bolt on mods but no internal mods. my coolant keeps randomly disappearing. im seeing no signs of any leaks or puddles on the ground. ive heard all kinds of ****, could be coming in threw the head and burning up in the combustion chamber, could be water pump. so i come to yall to help me figure out what it may be. ill be taking the truck on a 5hr drive in 2 weeks so id like to figure it out before then. any help would be great.
thanks
Old Jun 14, 2010 | 11:21 AM
budhayes3's Avatar
PT's Slowest Truck
The water pump gaskets are a common failure, and often won't leave any signs of leakage. They're a cheap easy fix too. I've heard of the heads cracking but don't have the specifics...there was a thread about it not too long ago. Search this section and maybe the GM General section and you should find it.
Old Jun 14, 2010 | 11:24 AM
awesome...thats what my buddy had said about the wp gasket. how hard is the fix for that? never really messed with to much motor stuff.
Old Jun 14, 2010 | 11:43 AM
budhayes3's Avatar
PT's Slowest Truck
Replacing the water pump is a piece of cake IMO, hardest part is getting the fan clutch off. If you search this section you'll find pics and methods of removing the fan clutch nut...
Old Jun 14, 2010 | 12:28 PM
Killtank's Avatar
+100 water pump gasket. The water pumps will last for ever but the gaskets wont!
Old Jun 14, 2010 | 06:04 PM
well gonna be trying to change the gasket my self this weekend. after talking to my buddy said you could remove fan shroud, belt and get to the 6 bolts on the water pump. said the most agravating part was getting the gasket to line up. does this sound correct to yall?
Old Jun 14, 2010 | 06:14 PM
neilownz's Avatar
Yes. And the fact that I don't have a drain ****, so you have to pull the lower coolant hose on mine.
6.0l RST
Nov 23, 2015 11:30 AM
bearden86
26
Nov 15, 2015 03:58 PM
sTNT971
Sep 26, 2015 04:22 PM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
