Where'd my mileage go?
Old Mar 2, 2005 | 12:40 AM
Default Where'd my mileage go?
I went from 450 miles a tank before the fuel light would come on, to only about 390MPG before the light went on.
Since then I've changed the fuel filter, PCV valve, 7 of 8 plugs (I'm lazy I'll get to the last one soon), oil change, and Cleaned my air filter (volant)
After all of that, nothing changed much.
I also think I'm down on some power, based on my highly calibrated butt-dyno ? I do have a Westers Tune, and am planning on getting a re-flash with some updated programming to reflect some upcoming changes, but this mileage decrease has be befuddled.
Do any of you have any ideas?
This is your run of the mill 5.3L with about 80k miles on it.
Old Mar 2, 2005 | 12:52 AM
F8L Z71's Avatar
Milage? 02 sensors?
I used to get high 300s in my Z71 but as time wen ton it got worse. My lil grey truck can only get about 370 before the light comes on.
Old Mar 2, 2005 | 12:53 AM
PappyDan's Avatar
Tribe Shaman
i ran some injector cleaner in mine and picked a few miles back up.
Old Mar 2, 2005 | 06:45 AM
quicksilverado's Avatar
I had the same thing happen. Tried new plugs, wires, o2s, and cleaned fuel system. None of the above helped.
Old Mar 2, 2005 | 06:52 AM
therock's Avatar
Default Is The Air Filter a K&N?
If the air filter is a K&N or another oiled gauze type, you may have an oil film on your MAF sensor element.
I would do a few WOT runs to make sure the filter was free of any over oiling and then contact clean the elements.
Try it, you never know.
Old Mar 2, 2005 | 07:32 AM
PGdynamics's Avatar
Double check your plug gap? Just a suggestion
Old Mar 2, 2005 | 07:50 AM
JERRY2500's Avatar
14 Second Truck Club
Bingo, We have a winner. I did the same thing. Just clean the MAF.
Old Mar 2, 2005 | 07:55 AM
nativetexan's Avatar
13 Second Truck Club
I read on here somewhere that the gas we get during the winter months is not as "good", especially around large cities. Just a thought.
Old Mar 2, 2005 | 08:20 AM
AKZ71's Avatar
Wish mine got 390. It only gets 270 or so tops
Old Mar 2, 2005 | 08:29 AM
marc_w's Avatar
If I'm good, I get 280miles.
