Where to start tuning ?
Old Jan 21, 2004 | 02:17 PM
redaddiction's Avatar
Default Where to start tuning ?
Hey guys it's been a long time since I've messed with edit could someone give me a little run down on what I need to do. I have a 4000 stall and I know I need to change some stuff for that and for the bigger motor so can ya'll help ?
Old Jan 21, 2004 | 06:19 PM
ttt come on someone has got to be able to give me a hand
Old Jan 21, 2004 | 07:06 PM
67SS509's Avatar
10 Second Truck Club
For starters:
-reset rpm limiter
-reset mph limiter
-reset shift points
-adjust IFR to give -6 to -8 Ltrims
-turn "cot" off
-adjust power enrichment versus rpm for a/f ratio 12.75 to 13 to 1 @ wot
-turn torque management off
-raise shift pressure
-adjust high octane timing table to 26-28 degrees @ wot above 3000 rpm
-copy high octane table to low octane table
maybe some more will chime in here with other pointers, there are a lot more!
Old Jan 21, 2004 | 07:08 PM
thanks alot I wll get on that tonight and see how it goes. how should I work around the huge stall ?
Old Jan 21, 2004 | 07:55 PM
67SS509's Avatar
You probably will have to work with your speed shift versus throttle position tables a little to make it more drivable. This will be in the trans calibration section. TCC lockup versus throttle position will need tweaking also.
shawn96gmc
May 17, 2016 04:15 PM
fillpot
Jul 26, 2015 07:21 PM
Ketis
Jul 23, 2015 12:37 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
4B11T
Jul 13, 2015 03:48 PM
