Where Is My PCV Located on my 05 L33? Not Kidding!
Old Feb 10, 2005 | 09:35 AM
  #21
gonzo 6.2's Avatar
I know a few jumped your **** for the one post of driving to tampa,I always figured they had the wrong impression.I had the idea that you are not a real aggresive driver based on how easy you were on the truck breaking it in.I bet if your truck gathers any oil it wont be much and even less with about 12K miles on it. that seems to be when these engines get freed up.I can see this catch can idea on a built motor set up to race with loose clearences.
Old Feb 10, 2005 | 08:40 PM
  #22
therock's Avatar
Thank You.
See you Around.
Old Feb 11, 2005 | 09:22 PM
  #23
qwank's Avatar
did anyone answer the question? i might have missed it. if not, theres no PCV on the 05's. GM went to a fixed oriface valve cover. the tube is the same but no PCV
Old Feb 12, 2005 | 04:20 AM
  #24
therock's Avatar
Default Yes!
That is what I believe to be the case. Call your dealership parts counter with the last 8 numbers of your VIN and ask for a PCV valve to make sure if you like.
Old Feb 13, 2005 | 06:09 PM
  #25
marc_w's Avatar
No PCV at all?
Or just not PCV valve?
therock - I just installed my AMW catch-can this weekend... I used the line I higlighted in my little post there off of the drivers valvecover. I was VERY surprised at the amount of vacuum pulled through there when the engine running... What happens if you start your motor and pull that line?
FWIW, I drove about 250 miles this weekend, and there is not a DROP in the can.
Old Feb 13, 2005 | 08:02 PM
  #26
qwank's Avatar
no valve. GM started using the fixed oriface valve in 03, and in 05 they just incorporated it as part of the valve cover.
Old Feb 14, 2005 | 04:35 AM
  #27
therock's Avatar
Default Not a Drop
That is a good thing. I hope mine stays dry as well.
Old Feb 14, 2005 | 07:58 AM
  #28
marc_w's Avatar
Thanks for the info qwank... that's good to know...
I took a look at the pictures on the very first page of the post here - my valve cover PCV-locatoin is similar, but different. There was no clamp on that hose, just your usual crimped 'barb' on the 1" metal male fitting coming off of the PCV-location.
Old Jul 30, 2005 | 06:45 PM
  #29
04BlackGmc's Avatar
10 Second Club
So you cant remove it right? Its made into the intake?
Pimpinpete
43
Dec 22, 2017 08:13 AM
cheyenne383
Nov 13, 2015 09:24 AM
JordanH
Oct 3, 2015 03:59 PM
peebzies
Sep 30, 2015 03:03 PM
old motorhead
Sep 29, 2015 08:22 PM
