where do you guys run your timing, big tex especialy
Old Mar 14, 2004 | 08:16 PM
parish8's Avatar
single digit dreamer
Default where do you guys run your timing, big tex especialy
i dicided to paly with my timing today, made about 15 1/8th mile runs with my timing all over the place.
i left it stock for a few runs, locked it at 20deg, then 24, then 28, then 32. all runs were within 1/10th and 1.5mph with no pattern.
the stock timing puts it at about 28deg to start and drops thru the rpms to something like 18deg.
should i try anything else? where are you guys set at?
i did run a 13.74 at 105 with the cut outs open and stock 6.0 timing. i hope i can pull that at the track(- the standard 4mph for gtech), track opens in 6 days
Old Mar 14, 2004 | 08:39 PM
blacksheep's Avatar
Set it at about 26 and it should be fine for running n/a or with a 125 shot.
blacksheep's Avatar
Set it at about 26 and it should be fine for running n/a or with a 150 shot.
Old Mar 14, 2004 | 08:45 PM
Ryan23silverado's Avatar
I have always done what Hypertech did with there timing increase. Like a coordinate (x,y) on the HOT and LOT timing table grab from cell (0.32, 1600rpm) and highlight from that spot all the way to the bottom right of the table. I increase those only. I have actually graphed a lot of this timing stuff out and you can plot where you are in the table over the entire rpm range.
In edit v1.4 the "x-factor" for truck engine timing is solved. There is a new table that shows a relationship between "Fuel ratio vs. RPM modifier" under ignition. I set this to zero so I know that the only table it can referrence for advance (besides KR) is the HOT table. This is important for boost especially. Before this new table came out I would have it set to see 15* adv. in upper rpms. However I would see something like 24* As you can imagine it is not cool to be unable to control your timing with lots of boost
I have it set to give 20* adv. in upper rpms with the 3.5" pulley. It is starting to warm up in Phoenix now though so that number will probably have to come down a few degrees soon
Old Mar 14, 2004 | 09:04 PM
Texas Terminator's Avatar
11 Second Club
parish, once you get the "boost", you may find that less timing will yield better numbers.
Old Mar 14, 2004 | 09:17 PM
Black Blown 02's Avatar
I'm wondering the same thing. I always thought more timing is always better.
I recently tuned to right before the point of detonation.
Started at 15 degrees declining to 11 degrees at redline.--ran 14.06 (g-tech)
Ended up at 15 degrees from start to redline--ran 14.00 (g-tech)
I thought I'd get more gains raising timing 4 degrees.
Does anyone know if there is a point where more timing does no good?
Old Mar 14, 2004 | 09:23 PM
BigTex's Avatar
I try to get at least 24*. I had it up to 28*, but lowered it when I got my nitrous kit finished up. I notice that sometimes it will be in the 20-21* range with certain temps and KR, and other times it will be in upper 20s with the same tune and no KR. I have a really long stretch of roas that I test on. I can do a 0-80 run, immediately stop, then do it again. I've seen low 20s and 5*KR on the first blast, then 0 KR and upper 20s the next. Runs are 1 minute apart. Must have something to do with IAT and ECTs.
Old Mar 14, 2004 | 09:27 PM
Yeah, I ended up zeroing my IAT vs. load table just to get some consistency.
Old Mar 14, 2004 | 09:37 PM
StupidFast's Avatar
Do not zero your IAT vs MAP table, Black Blown 02. You can run alot of timing down low, for a huge torque increase. Then you can slowly take timing out as the air temp goes up.
On the dyno 2* of timing at low rpms was worth 11rwtq, with my ATI. I had my timing set at 28* with pump gas at 11lbs, no detonation problems. As the air temp went up I started taking timing out. First by 1 and 2 degress and then as the air got hot 6 to 10 degress.
Just my opinion.
Old Mar 14, 2004 | 09:48 PM
Just my opinion.
When you say alot of timing down low, what rpm do you mean?
Right now, I run 20 degrees until 4200 rpm, then 18 until 5000, then 15 from 5000 to 6000 (where 90 percent of the 1/4 mile run is.) I stall to 4000 and my shifts drop to 5000.
I like that idea. If the outside temp will stay consistent around here I will try it.
