Where is the A/C wire to tap into for my VSC?
Old Mar 29, 2005 | 02:15 PM
Default Where is the A/C wire to tap into for my VSC?
i have had people on here try to help me find it but i still cant...i need someone to help me find this damn wire ..i know its green thats all, is it dark green light green? have a white stripe/..where exactly can i find the a/c compressor wire?
Old Mar 29, 2005 | 02:45 PM
It is the all dark green wire inside the loom next to the batt distribution block. You can also get a light tester and check the wire before you hook it up. If the ac compressor is on, there should be a positive charge on the green wire.
Old Mar 29, 2005 | 02:50 PM
ridered's Avatar
where are you located i can find it
Old Mar 29, 2005 | 05:23 PM
do u mean where do i live?
Old Mar 29, 2005 | 05:24 PM
will the wires be bare or will they be wrapped in tape under the loom?
Old Mar 29, 2005 | 06:52 PM
Okie5.3's Avatar
start from the ac comp. and work back towards the battery. the loom should run across the support below the radiator if i remember correctly. if you are located closer to tulsa i could help you out.
Old Mar 29, 2005 | 07:58 PM
well thanks for all the help guys...i finally got it figured out and everything works..i just tapped into it under the fuse box where it connects to the a/c relay
Old Mar 29, 2005 | 09:13 PM
SnakeOiler's Avatar
That would be the place
Old Mar 29, 2005 | 10:31 PM
ridered's Avatar
yeah, i meant where are you located in case you needed help. i would like to meet up with you sometime to see what that 216/220 cam is like.
Old Mar 29, 2005 | 10:47 PM
goshawk23's Avatar
Truck addict
thanks for asking this question. this has been something i have been needing to do for a long time.
