When to switch to synthetic oils???
Old Sep 9, 2006 | 07:07 AM
n737nc's Avatar
Default When to switch to synthetic oils???
Morning guys!
Just curious, at what mileage should I start switching over to synthetic oils? I'd like to do the engine, trans and rear end. I'm at about 600 miles right now, and I've always heard that you should wait till 5000 miles before you switch them over.
I'd like to hear your thoughts....
Old Sep 9, 2006 | 08:11 AM
ranwalk's Avatar
I'd wait til around 3000 to switch engine oil.
The rear diff in these trucks allready have synthetic fluid in them.
Personally I wouldnt worry about switching the transmission fluid.
Old Sep 9, 2006 | 08:18 AM
ss64impala's Avatar
you should be done with your break-in by your first oil change. i'd switch it then. unless you drive like me, mine was probably boke-in before the first tank of gas
Old Sep 9, 2006 | 10:08 AM
o2man98's Avatar
You can switch over at any time. I typically change all my new vehicles out at around 1000 miles for engine oil, 5000 for diffs, and whenever I feel ambitious with the trans fluid unless a manual trans then it is at 5000 with the diffs. It will not hurt anything.
Old Sep 9, 2006 | 11:47 AM
budhayes3's Avatar
PT's Slowest Truck
I switched my engine oil to Mobil1 at about 700 miles...still using conventional trans fluid. As mentioned above the rear diff has syn from the factory, and I switched my front diff over at about 15k.
Texas5.3_1251
Mar 5, 2016 08:10 PM
max_ta
Nov 10, 2015 07:50 PM
Go5.3tt06
Sep 14, 2015 02:11 PM
Brandonlflr12
Sep 8, 2015 09:01 PM
jtphelps289
Sep 1, 2015 08:58 PM
