wheel hop
What kind of mods were made to drop the truck?If your truck has a stiffened ride to avoid bottoming it won't matter what kind of traction bars you run as the only suspension travel is from the flex in the tires.
Below is a quote from travis at caltracs when I emailed them to ask if they have any set-up instructions for their bars.
Originally Posted by travis @ caltracs
We recommend starting out in the bottom hole with about a 1/2 turn of even preload with the drivers weight in the truck. The more preload you add the less action you get. The less preload you have the more action you get (harder hit). Recommended adjustment range is between an 1/4" air gap above the spring to 1 full turn Max preload. If you have further questions please call me at 1-800-607-2266 Thanks
George C....
Sep 11, 2015 04:45 PM
