wheel hop
Old Apr 5, 2004 | 11:28 PM
Flyer's Avatar
I'm not sure ... but I think the Cal-Tracs are like ladder bars.
What do you mean by side to side movement?
Old Apr 5, 2004 | 11:57 PM
What kind of mods were made to drop the truck?If your truck has a stiffened ride to avoid bottoming it won't matter what kind of traction bars you run as the only suspension travel is from the flex in the tires.
Old Apr 6, 2004 | 08:30 AM
Yes cal tracs are similar to a laddar bar but not as beefy.
Old May 3, 2004 | 11:35 PM
kalezcustomz's Avatar
Hey got my cal tracs installed runs good seems to stip and looks like it lifted the back up about 2 inches where do you guys have yours set i put them were tey are touching the leafsprings
Old May 3, 2004 | 11:43 PM
BlownChevy's Avatar
blownerator
25 Year Member
I set mine so they are "just" touching the springs.
Old May 4, 2004 | 06:32 AM
2ksleeper's Avatar
Below is a quote from travis at caltracs when I emailed them to ask if they have any set-up instructions for their bars.
Originally Posted by travis @ caltracs
We recommend starting out in the bottom hole with about a 1/2 turn of even preload with the drivers weight in the truck. The more preload you add the less action you get. The less preload you have the more action you get (harder hit). Recommended adjustment range is between an 1/4" air gap above the spring to 1 full turn Max preload. If you have further questions please call me at 1-800-607-2266 Thanks
sprayed99
Sep 21, 2015 04:47 PM
Glenn98ZM6
Sep 18, 2015 07:31 PM
George C....
Sep 11, 2015 04:45 PM
dselby25
Sep 11, 2015 05:03 AM
the owl
Sep 4, 2015 04:09 PM
