What's needed for 243 s on a LQ-9
MASS seller approved
I found a nice set of 243 off a 06 LS2 GTO and my qeustion is what is needed to swap them out . Before the heads go on I'm gonna swap the rockers for 1.7 and do different springs . My qeustion Is about what push rods will I need and thickness head gasket . I will be doing a came while it ripped down but that another ? that I won't annoy for a answer at this time . Has anyone swapped the 243 on to a LQ9 and how was the results.y mods are as follows : Dynatech LT with cats, Gibson cat back, flexalite 282 twin fans , Trickflow UD pully W/ over for alt, P&P BBK 80mm TB, taylor 409 wires, yank2600 stall,FLT lvl 5 4l65,410 gears W/ eaton posi,K&N intake and Nelson tune. Sorry for the long ? I just figured the more u know about what I got the better u can help to answery ? about putting the heads on. Thanx in advance!
The normal head swap stuff. Stock head gaskets, head bolts, if your doing a cam get some hardened push rods. Also might need a new timing cover gasket, water pump gaskets, timing cover seal,crank bolt.
The 243s will raise the compression to alittle over 10.3:1 I believe. A 224/224 112 LSA cam would be perfect IMO.
I'd bet your static c/r would be closer to 11:1. High 10's anyway depending on head gasket. I'd use stock GM LS2 gaskets. You have 1.7 rocker arms now. Use them unless you have a serious wad of money burning a hole in your pocket. Have Pat G spec you a cam, springs, and p'rods. Retune. Enjoy
