whats the difference between the manifolds
Old Sep 30, 2007 | 08:27 PM
xdanny510x's Avatar
Default whats the difference between the manifolds
suchs as in brand name and for example the weiand intake manifold for ls1 type engines and the fast etc etc
they claim to add hp over our stock ones
but yea i would want to run the ls6 manifold but u gotta change a lot of shet so thats why i was planning on the fast or weiand type manifold...
Old Sep 30, 2007 | 08:30 PM
nightrunner's Avatar
Mr. Obvious
not sure about price, i guess it depends on where you get.
weiand - aluminum - a large heat soak, very bad, very minimal gains
FAST -expensive but what most guys run if you dont stay with gm
most truck guys go to a LS6 if they swap manifolds. i would swap heads before intake manifold
Old Sep 30, 2007 | 08:32 PM
dirt track racer 81's Avatar
fast is composite and is a two piece to were you can have a 78mm tb or a 90mm tb..the bbk can accept a 85mm tb..then the professional products accepts to a 90+mm intake..for performance differences look on ls1tech and do a search..
Old Sep 30, 2007 | 08:34 PM
im not sayin that heat soak doesnt happen on aluminum intakes, but id like to see a dyno run with the motor fairly cool and then another dyno pull with the intake hot
Old Sep 30, 2007 | 08:36 PM
xdanny510x's Avatar
maybe i should be the first to try one of these babys and tell u the results ... this was gonna be one of my next mods.... i was going to by the fast intake last week but my rear went out and i just go my truck back...
Old Sep 30, 2007 | 08:38 PM
Mr. Obvious
the fast and weiand require the EXACT amount of changes as the LS6, they're all car style intakes...
Old Sep 30, 2007 | 08:40 PM
you have to change the sames things as you do with the ls1 for the fast..i have the ls1 intake now and debating on either a bbk 85mm or the big PP intake
Old Sep 30, 2007 | 08:41 PM
xdanny510x's Avatar
so i would have to change the water pump n other things too???
Old Sep 30, 2007 | 08:42 PM
Mr. Obvious
Originally Posted by dirt_track_racer_81
how is that any harsher than what you said?
