What ya think, Granatelli trans tuner vs servos.
I saw this on the Granatelli website when I was looking at the Predator tuner, what ya think about it?
http://granatellimotorsports.com/transtuner.htm
Jim
Jim
It looks similar to the B&M shift thing, it just raises the trans line pressure if they are similar.
If you are considering those two options, I would look at a TransGo shift kit with a 'Vette servo. That would work way, wyay better than either of those two optinos you mentioned. My favorite thing about that kit is fix of the 2-3 overlap shift, it makes it very clean.
You can also adjust the 1-2 upshift with the washers included to get fimness you are looking for...from quick and tight to neck snapping.
It would probably run you ~$100 for the kit + $15 for the 'Vette servo + ~$150 to install. Upside is a smarter trans, much cleaner shifts, and a longer lasting trans. Downside is costs considerably more than you are probably looking to spend.
To hardh of a shift is to bad. Raising the line pressure to much with the PCM alone is to bad too.
If it were me ... TransGo hands down! I'd stick with the billet servos and conservative on the transgo or slightly more agressive with the shift kit and corvette servos.
silverstreak07
Aug 23, 2015 07:09 PM
GreyChevy
Jul 7, 2015 08:57 PM
