what would it take?
Old Oct 21, 2004 | 06:34 PM
04LS1GTO's Avatar
Default what would it take?
what would it take to get n/a 400-450rwhp out of a stock bottom end 6.0l. I know I will need a pretty big cam and probably some head work. some #'s from some proven combo's would be nice
Old Oct 21, 2004 | 07:23 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
That's a pretty big goal. I would think a good set of heads from GTP and a cam somewhere around the 240/600" range would be a good start. I would also think that injectors and fuel system are gonna be another problem.
Old Oct 21, 2004 | 10:01 PM
F8L Z71's Avatar
I really don't see it happening N/A unless you have a special built block.
I could see 400rwhp or maybe a smidge more with a full blown heads/cam (high compression) and all bolt-on setup but it is going to depend on your drivetrain loss also. A 4l80E with tranfercase is gonna rob some of that.
Old Oct 21, 2004 | 11:54 PM
zippy's Avatar
i'd recomend checking into the thunder racing t-rex cam...
Old Oct 22, 2004 | 11:18 AM
sfj
you might pm stupid fast he had a blown 6.0 with 502hp/508tq i think that was more than fast it was stupidfast and it was awesome and was on stock bottom end i believe a smidge over 400 seems kinda low??? mebbe is just me but seems low you should be able to achieve your goal good luck
Old Oct 22, 2004 | 03:45 PM
04LS1GTO's Avatar
thinking about ditching the 4.3 in my s-10 and swapping a 6.0 in. would I be better off with a 5.7 ls1? seems like those guys hit 400rwhp with full bolt ons and a good cam. also I will be having my current 4l60e built to the wood
Old Oct 22, 2004 | 04:00 PM
RED2K's Avatar
You would need a really good set of heads and a healty cam. You would need about every bolt on as well
