what would this get me ??
Old Aug 26, 2003 | 01:21 PM
Banned
Default Re: what would this get me ??
if you go with a cam like i was talking about and some good tuning you will be in the atleast 350 to the wheels.
Old Aug 26, 2003 | 01:26 PM
Yelo's Avatar
Slowverado - I like that number MUCH better......
I was on the phone to Comp cams a few minutes ago and they can grind that custom grind no problem with only a 2-3 day wait over a stocked cam....I think I will go with that 215/215 .555 112 grind unless anyone has a better idea
Old Aug 26, 2003 | 01:46 PM
GREGGO's Avatar
Always guess low. That way you won't be dissapointed. I missed that part about the CR bump. But I still thing it wil be about 300-325 rwhp. Have you dynoed the truck yet? I would guess by the time you ran that your in the 280rwhp range. I would not waste money on the rockers if I was buying a cam. I would just get a bigger cam. Your loosing a bit more through parasitic loss with that beefer driveline that us 1/2 ton guys.
Old Aug 26, 2003 | 02:09 PM
Yelo's Avatar
the only current hp #'s I have come from my g-tech pro comp.......291 hp......I find that number a little hard to believe but it does match up with the 15.32 I have run so it may be close...that 15.32 ET is g-tech timed as well (on an airport runway so I know it was flat and straight)
I will hope for 325 and if I see more than that I will be happy !!
Old Aug 26, 2003 | 02:22 PM
1BADHD's Avatar
Keep me up to date on your mods and what numbers you put down. I am getting ready to break open the engine on my HD this winter. Still making a parts shopping list.
Old Aug 26, 2003 | 02:25 PM
XLR8NSS's Avatar
Adkoonerstrator
I think those 6.0L's dyno in the 280-290 range don't they??
I would say you could see 340rwhp with that combo. Kinda depends on the level of head work and the cam though.
Like Greg said forget those rockers and just get a cam with the lift you want built in. If you want to get rockers go with the Yella Terras.
Accessory swap looks like a go for this weekend but, the LS6 intake swap will have to wait. I think it will be a relatively straight forward swap and really clean things up by getting rid of the EGR and consolidating the PCV system.
Old Aug 26, 2003 | 02:44 PM
Yelo's Avatar
no problem......
Old Aug 26, 2003 | 04:14 PM
StreetSweepa's Avatar
Would you need somethin other than the stock 6.0 springs for this cam? How would it be at idle? What's a cam like this run price wise?
Old Aug 26, 2003 | 04:32 PM
Yelo's Avatar
in the order that they were asked:
yes, you need ls6 springs, it would idle almost the same as stock, $406.95
Old Aug 26, 2003 | 04:46 PM
Banned
Stupidfast put down like 350+rwhp with stock heads, asm headers, bolt ons, and a smaller cam with his 6.0...if you have worked heads and a more powerful cam you should see better numbers. he put that down through 4.10s and 20"wheels/tires though.
