what would this get me ??
Old Aug 26, 2003 | 12:40 AM
Yelo's Avatar
Default what would this get me ??
I am putting the twin-turbo project on the back burner for now for various reasons....I do have a few plans that I fugure will go well with the TT setup if I ever finish it (and will work well on ther own as well)
what kind of power numbers do you think I will get from this combo ??:
1. 6.0 aluminum heads with mild porting and polishing/gasket matched/milled .010-.020, stock valves, LS6 springs, SLP 1.85:1 rockers
2. stock LS6 cam (I still need low-end torque for towing)
3. gasket matched 6.0 intake...no other intake mods
4. either Edelbrock TES headers or TOG headers (both are mid length....I know the Edelbrock horror stories)
5. ported and polished throttle body
6. custom LS1Edit tuning
7. Stock 6.0 Bottom End
8 E-fans
9. POSSIBLE swap to f-body accessories and LS6 intake if XLR8NSS works all the kinks out of his swap
I know this is fairly mild but I am looking at adding forced induction to it in the future and want to keep it VERY drivable until then
so---what do you think I will see ??
Old Aug 26, 2003 | 12:42 AM
Banned
Default Re: what would this get me ??
you'll see fbodies as you pass them in your rearview
Old Aug 26, 2003 | 12:44 AM
Banned
i would go with a different cam though...if you want low end torque that's not the cam for you. that cam peaks very very high. go with a cam like SMOKEUR5.0's...215/215 .555ish on a 112
Old Aug 26, 2003 | 12:50 AM
Yelo's Avatar
Slow....thanks for the advice....I'll look into that
do you know the manufacturer of his cam ??
Old Aug 26, 2003 | 01:01 AM
Banned
probably comp...it's a custom grind. you can have any one of the companies making LS1 cams make you a custom grind of any specs you want. if you want ultimate low end i would get ahold of big tex and see what he says about a cam for your setup.
Old Aug 26, 2003 | 01:28 AM
GoldenVelvet's Avatar
The Grand National guys find an advantage in using a relatively small cam in that it helps with turbo lag
Old Aug 26, 2003 | 09:58 AM
GREGGO's Avatar
That combo will probably get you 300 or so to the wheels.
Old Aug 26, 2003 | 10:00 AM
BlownChevy's Avatar
blownerator
25 Year Member
It would be a nice kick in the pants!
But you all know what I say................Radix!
Slap a radix on that combo and you will really have a runner from hell!
Why did you put off the TT setup?
Old Aug 26, 2003 | 12:14 PM
Yelo's Avatar
I put off the TT project mainly because of heat concerns....I need a summer tow vehicle that will function 100% of the time when it is 130* outside....a TT produces ALOT of heat and an intercooler wouldn't help much at all when it is that warm outside
the RADIX IS still an option....I don't have the 5 grand to drop on it currently but in 6 months or so I may
thanks for the info guys.....
Old Aug 26, 2003 | 01:17 PM
Yelo's Avatar
300hp or so at the wheels ??......
So you think that combo is only good for 30ish rwhp huh??....really ??....even as mild as it is I was kinda hoping for more ...I kinda hoped the cam, porting, tuning and CR bump from the milled heads would be good for 60-70 rwhp....oh well, I can dream right
