What will this thing run...
Old Aug 13, 2004 | 04:22 PM
Allgonoshow's Avatar
Cool What will this thing run...
Weather permitting, I have chance to go to the track this weekend,any
predictions with all mods in signature. I'm thinking high 14's.
Also, any launch tips, it's 2wd. Brake stand at what rpm? pull abs fuse ?
I tried brake stands in my y2k truck and it went weird as i eased off brake pedal and rear wheels started moving, like ABS was kicking in due to front wheels not moving. Shifter in what gear, use automatic or shift manually?
First time, so any tips are worth some time.
Thanx in advance
David
Old Aug 13, 2004 | 04:42 PM
Mangled03gmc's Avatar
Baltimore Whore
Thanx in advance
David
this is the way that i do it.brake stall it to just before the back tires break loose then hit it when the goes green.if you spin just pedal it a bit.run it manualy and then run it in auto.
Old Aug 13, 2004 | 05:23 PM
superchargedchevy02's Avatar
Thanx in advance
David
mid to low 15's with what you got I would try to launch from dead idle and then try it with a little gas about 2 - 2500 rpm I would just put it in 2nd and leave it there thats what I did and ran good times. I hope i'm wrong and you do run high 14's that would be great.
Old Aug 13, 2004 | 06:30 PM
Black Blown 02's Avatar
I don't know if I'd leave it in 2nd. He might be on the rev limiter before the end of the 1/4.
Old Aug 13, 2004 | 07:15 PM
with the same mods before my SC I never hit the rev limiter
Old Aug 13, 2004 | 11:32 PM
What rear ratio do you have?
Old Aug 14, 2004 | 05:56 AM
Default What did you run
What kind of times with your previous setup, and now with the blower
David
Old Aug 15, 2004 | 11:27 AM
David
3.42 and my times were 15:87 in summer 15:53 in winter and now with the detonation problems only 14:70 without good tires
Old Aug 15, 2004 | 11:35 AM
Allgonoshow has 3.73's. He'd be turning more rpm's at any given speed.
Old Aug 15, 2004 | 03:31 PM
there is no doubt he is turning higher RPM but I think he will still have enough time before hitting the limiter
Vortec350ss
Oct 10, 2015 09:11 PM
Lthompson
Sep 21, 2015 07:06 PM
lxcoupe
Sep 21, 2015 11:53 AM
xtrooper89
Sep 21, 2015 06:03 AM
