what timing chain are you running?
Old Mar 11, 2009 | 08:23 PM
BlackGMC's Avatar
Resident Retard
Default what timing chain are you running?
I have got another cam swap coming up hopefully soon, just wondering what timing chaing everyone is running?
Also when replacing it, is there any special advice or tips?
Thanks
Old Mar 11, 2009 | 08:36 PM
00ChevyScott's Avatar
Wearin' da big hat
You should get that edlebrock 2 peice timing cover since u change cams so much, but as far as timing chains go, i think most people are gonna say the ls2 timing chain.
Old Mar 11, 2009 | 08:37 PM
dirt track racer 81's Avatar
im rocker the stocker..im too cheap..one of these days ill get somethin on there
Old Mar 11, 2009 | 08:41 PM
sonoma43's Avatar
Stocker!!!
Old Mar 11, 2009 | 08:46 PM
SincalT/A's Avatar
stock ftw
Old Mar 11, 2009 | 08:47 PM
GMCtrk's Avatar
i'll probably just keep my stock one since you have to remove the oil pump to change it and I've seen way too many cases of o-rings getting pinching requiring a complete tear down again. Plus, when was the last time you heard of one breaking.
Old Mar 11, 2009 | 09:09 PM
hirdlej's Avatar
Stock one isn't ideal, it's too sloppy for a performance application. Although the stock chains are made for GM by cloyes, they're intentionally made sloppy so that the robots can load the chain onto the front of the engine with ease. A good timing set will not have slop in it. The sloppyness of the stocker will allow for the cam timing to change during drive along with causing the valvetrain to "Snap" or "lash". This snapping or lashing is hard on lifters, pushrods, rockers and springs. When replacing the timing set use this kent moore tool: for removing the crank sprocket, then take your old crank sprocket to tap on your new crank sprocket and seat it into place. The tool is only $10 and will not scratch the crank or hurt the crank gear. It's a LS1 specific tool: http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem= Then install chain, check your valve events, adjust accordingly the reassemble engine
Old Mar 11, 2009 | 09:17 PM
BigKID's Avatar
I'm running a Rollmaster single. Went from my H/C 5.3 to the LS1 to the 370 I currently have. Still working great.
Old Mar 11, 2009 | 11:54 PM
dlt76028's Avatar
i've got an ls2 timing chain... its alot thicker
Old Mar 12, 2009 | 12:06 AM
Derek @ EDO's Avatar
FormerVendor
Im running the IN-motion setup, you can get it for around 100.00 and its adjustable!!
Texas Speed and Scoggin Dickey stock them.
