what tha heck
#21
the 01 and newer 6.0's have the same crank flange as all 4.8/5.3/5.7, the older 6.0's(the ones with iron heads) have a thinker crank flange. i shouldn't say it is worthless, but i don't know what would need to be done to make it work.
#24
Adkoonerstrator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by slowverado:
<strong> to make what work? you saying that i can't put my 5.3 heads on the new block and just drop it right into my truck? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Reread what parish8 said
"the 01 and newer 6.0's have the same crank flange as all 4.8/5.3/5.7, the older 6.0's(the ones with iron heads) have a thicker crank flange."
This means that it won't be a direct drop in. You can either have someone machine the flange down or buy a crank from a 5.3/5.7/'01+6.0L.
John
John
#25
Banned
all i would have to do is buy an 01+ crank and the problem would be solved? right? i was thinking about a 4" stroker crank anyways so that would desolve any problem right.
Matt
Matt
#26
Adkoonerstrator
Any other 3.622" crank besides the 99-00 6.0L ones will work. The 5.3L motors, 5.7L LS1/LS6 motor, and '01+ 6.0L motors have the correct crank.
If you get the 4" crank it will also solve the problem but require new pistons to work with the longer stroke. I think you're getting new pistons either way though right? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
John
John
#27
Basically, the block is the only thing you'd want from the one you bought. The crank wont fit in your truck. The heads are worthless. Pistons... well, you were going to replace them. I guess you could reuse your rods.
#28
You shoulda went ahead and bought an 01+ 6.0L since the heads are the same design as the ls6 heads. Also you would want to get the 5.3 heads you are talking about using matched to the bore size you will be using. No use having a 3.78-3.90 bore head on a 4.03 bore block. Then, if you didn't want the 6.0L heads you could have sold them for around $500.
#29
Banned
i didn't buy the other block, i have an offer for a short block from someone on this forum and i'm gonna buy it as soon as i get the money. i think he said it was an 02 6.0 block crank etc.
Matt
Matt
#30
STOP FU$%ING AROUND mixing and matching a bunch of junk together, just buy a complete running 6.0(01 or newer) and get everything you need in one shot. then decide where to go from there. it is hard to beat the 6.0 for a starting platform unless you are looking for an aluminum block.
