what to start with
Old Jan 21, 2004 | 03:48 PM
Default what to start with
Looking at buying a new truck. Would like to swap in a bored and stroked 6.0. I would like to know which way to go about doing this(expense wise). Start with a reg. cab v6. or v8. V6 is 4k cheaper. save money for the engine since I will tear it out anyway. Is the v6 electronics compatible. what do I need to know to make this the easiest process as possible.
Old Jan 21, 2004 | 04:12 PM
Yelo's Avatar
start with a V8.....it then becomes a direct swap, if you start with a V6 you have to change most of the electronics in the truck
Old Jan 21, 2004 | 04:25 PM
damn the flies. Well I was just hoping to save the money. Any good ideas about a 6.0 buildup. money total spend on engine cant be more then 6k.
Old Jan 21, 2004 | 04:39 PM
Yelo's Avatar
****..with 6K to put into the motor you can build a Heads/Cam/Stroker 421 that will thump out 450+hp, or just buy a stock 6.0 and bolt a RADIX supercharger onto it...that combo would be good for 450+hp as well
Or you could go with a heads/cam 6.0, a Yank TT3000 stall converter and a BUILT tranny to make sure you can put the power to the ground reliably....
A good set of Stage 1.5 6.0 heads and a 212/218 .558/.563 115lsa cam would net you pretty close to 400hp at the crank after tuning
Old Jan 21, 2004 | 04:58 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
I too say get the V8. You will drive yourself nuts looking around for the "things" that the V6 trucks don't have. Plus, I don't know if you can get any amenities such as power windows and locks (LS package) with the V6 truck, (not sure tho). Plus, you will always have the brand new V8 that it came with to either put back in when you sell it (and keep your kick *** stroker bullet) or sell the original motor. The ECM is different in the V6 truck, and I know you will need things like a starter, fan, maybe a radiator.
Old Jan 22, 2004 | 08:26 AM
thank you all. yes I would love to build a 421 with heads, cam, etc. Forge it and throw on a turbo, supercharger or some funny gas. thank you for your help
flatblack83
Jan 3, 2026 07:10 PM
Texas5.3_1251
Mar 5, 2016 08:10 PM
11MPG
Sep 10, 2015 08:34 PM
muncie21
Sep 7, 2015 09:55 PM
mayko
Sep 7, 2015 12:24 PM
