what size pushrods?
Old Mar 6, 2007 | 01:49 PM
LARRY01Z28's Avatar
Default what size pushrods?
what size push rods would i use in a srtock 6.0L with a 2002 Z06 cam?? thsoi is what it says on the website. thanks.
New for the 2002 Corvette, the 405hp camshaft for the LS6 engine option. Please note that this cam has approximately a 0.050" smaller base circle than a stock LS1 camshaft. This smaller base circle will require longer pushrods for applications with stock length valves and no milling for the head surface. It is imperative that you check your pushrod length when purchasing this cam. The 2002 Z06 cylinder heads use a longer valve to make-up this difference
Old Mar 6, 2007 | 07:20 PM
Phantom's Avatar
11 Second Club
i thought most people just used the 7.400 with that cam...
Old Mar 6, 2007 | 07:38 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
What are you doing with a stock 6.0L anyway?
Old Mar 7, 2007 | 07:55 AM
LARRY01Z28's Avatar
ill never tell.
Old Mar 7, 2007 | 08:12 AM
LARRY01Z28's Avatar
ok, ive heard 7.4 and 7.450 so i guess ill just check it. thanks larry
Old Mar 8, 2007 | 08:03 AM
LARRY01Z28's Avatar
any other opinions??
thanks larry
jtphelps289
Sep 29, 2015 12:00 PM
twake_410
Sep 25, 2015 10:09 PM
Closer_2001
Sep 24, 2015 09:15 PM
97_ek
Sep 23, 2015 09:16 PM
