What size injectors???
Old Nov 2, 2004 | 04:54 PM
8ALTNG's Avatar
Default What size injectors???
I am in the middle of the 4.8 build up and I need some help with choosing the right injectors. When i had the radix it had 42lb injectors. the engine is going to flow some serious air and fuel. It might be n/a but I wouldnt be sure about that. Anyone have a idea??? Thanks
-matt
Old Nov 2, 2004 | 06:23 PM
L-EATER's Avatar
11 Second Truck Club
-matt
My Ford 42lbers are supporting a 6 liter with a cam, 10psi of boost, and a 100+ dry shot. Without knowing your specific combo I cant make a recommendation, but I would think that 42's would support all but a full race 4.8
I know there are 2 schools of thought on injector sizing, but I have always felt you are better off with the smallest injectors that can safely support the power level you are shooting for. Just my .02
Old Nov 2, 2004 | 06:33 PM
F8L Z71's Avatar
I like to er on the side of almost to big of an injector.
I have not check my duty cycle on these 42s at max boost but doing HP calcs I am pretty sure I am over their safe limit (est. 545rwhp) With the 6.0L and 18psi or so I plan on running 55-60lb injectors. Just havn't figured out which yet
Old Nov 2, 2004 | 06:45 PM
8ALTNG's Avatar
F8L- what Brand injectors are you going to use??
Flyer's Avatar
EFILive tells me my injectors are maxed somewhere around 6200 RPM. That's only running ~8psi too.
Old Nov 2, 2004 | 07:50 PM
slowprocess's Avatar
Anybody might know what injector I need to go with. Right now I'm using stock 02 injectors, but I want to go with a nice shot of spray, so what would I need to look for?
Old Nov 2, 2004 | 07:57 PM
F8L Z71's Avatar
The 8.1L marine injectors. I guess I should say the 55-60lb injectors would be the rating at our ls1 fuel pressures too. Not like using an SVO style injector.
Stainless Works
13
Nov 5, 2015 03:31 PM
WICK3DxGATA
Aug 31, 2015 07:21 AM
maxspeed05V
Aug 12, 2015 06:29 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
jrplz
Jul 9, 2015 12:07 AM
