What is this sensor and do I really need it?
Old Nov 26, 2007 | 01:18 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Default What is this sensor and do I really need it?
I changed oil pans. This sensor was in the stock pan about 1/2 way down the deep part of the pan. Anyone know:
a) what sensor this is (looks like oil pan level? I has a 'float' but goes in horizontally... )
b) if I need it (the new pan is for an LS1 and has no provision for this sensor)
c) about where I should put it in this pan:
Old Nov 26, 2007 | 02:06 PM
knuckles's Avatar
i think that is for oil level it lets you know if getting to low on oil. if you were to not use it you would see the add oil light or you could splice the two wires together.
Old Nov 26, 2007 | 02:27 PM
thunder550's Avatar
High on diesel fumes
What he said.
Old Nov 26, 2007 | 03:30 PM
kbracing96's Avatar
Or you can set it to ''not report" the code and to show "no MIL" in the low oil level in the tune.
Old Nov 26, 2007 | 03:39 PM
v8
17,16,15,14,13,12,11 Drvr
yep low oil indicator
Old Nov 26, 2007 | 04:34 PM
I AM A MOTHERF*CKER
Yep -- I can add it easily. I'm just trying to figure out where -- too high and it's always on.
The new oil system is going to run about 8 qts. During operation, there will be some in the lines, the oil cooler, the big second filter, etc. The pan capacity is 7 quarts. Should I put the sensor at the 3 quart (from empty) line? I'm not sure how much will be circulating at any one time.
Old Nov 26, 2007 | 04:52 PM
thunder550's Avatar
I'd probably go higher than that. I had my low oil warning come on once, and the oil level was barely touching the bottom of the dipstick. What I would probably do.....see how much oil your stock pan holds at the stock level of the sensor, and put it at roughly the same level in the new pan. Or try and measure to see where the bottom of the dipstick sits, and put it in a position to come on when the oil level drop to the bottom of the dipstick.
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
Wrecker 426
Sep 30, 2015 09:39 PM
WICK3DxGATA
Sep 24, 2015 06:56 PM
