At what PSI are Delphi 42#ers tested at?
those 43lb/hr injectors will flow 49.7 lb/hr at 58psi or 4 BAR of rail pressure.
the industry test pressure for GM injectors is 43.5psi or 3BAR of fuel pressure. Every GM truck since 1996 has been regulated to 4BAR.
peace
Hog
Part Number 17113739 (OE Part # 25176061)
Direct fit for short G.M. LS1 SUV injectors
Static flow @ 37.95lb/hr @ 43.5PSI / 300KPa (4.31 g/s = 398cc/min)
Static flow @ 43.82lb/hr @ 58PSI / 400KPa (4.97 g/s = 460cc/min) *
Dynamic flow (2.0ms/10.0 ms(pulse width / rep rate)) 6.0 lb/hr @ 43.5PSI (0.748 g/s @ 300KPa)
Coil Resistance: High Impedance / High-Z (No ECM driver modifications required)
Nope...
100% DC or static.
Thanks for the correction, thats what happens when IFRs are mis-quoted, they have 3BAR standard test pressure for a reason.(which isnt really to valid as everything is 4BAR nowadays-at least for now, 5-150 BAR is just around the corner for the V8's,depending on what GM decides on)
peace
Hog
peace
Hog
Tydriver
45
Oct 23, 2015 09:19 PM
lycominghunter
26
Sep 25, 2015 07:50 AM
