what plug wires with Longtubes
#21
While I fall in with the stock wire group, if you just absolutely need a set for clearance purposes, ccperformance from LS1Tech will custom build you a set of MSD's. I have the older style Dynatech's with the stupid humped up tube and I had them put 45 degree boots on the plug end, as it affords more clearance than the bendable boots.
#26
i cant believe anyone is still using the stock wires on a performance engine after seeing the test on them. they have almost a 1000 ohms resistance. have seen one test on a 5.3l that got 15hp just by changing stock to granatelli wires
#27
I bet that test was in a magazine to correct?
#30
\edit link https://www.performancetrucks.net/fo...d.php?t=453455
