what is this noise?
Old Oct 13, 2013 | 12:05 PM
brizzle815's Avatar
Default what is this noise?
ls1 cold start. piston slap? - YouTube
ls1 warm up, piston slap? motor has been running 5 to 8 mins - YouTube
what do you guys think?
i was told motor has made this noise since motor was put in 4 years ago.
truck runs very good no leaks and no smoke.
I have changed oil (runing 10w 30 non synthetic) no metal or anything in oil
thanks
Old Oct 13, 2013 | 01:06 PM
TechGM's Avatar
Registered User
Sorry I can't make out sound in video microphone picking up too much. But this is easy help for you. Is the noise at crankshaft speed or camshaft speed? That'll tell you if its lower end or valve train. 2-1 crank to cam
Old Oct 15, 2013 | 08:11 AM
brizzle815's Avatar
I'm not sure bout sound speed
I will look at it again and try to make a better video
I was hoping more would chime in cause the more I read a lifter problem is pretty common if that's what it is.
If it is what lifter do I go with? Ls7?
Thanks
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
Velocity1
Oct 2, 2015 08:01 AM
tim wellington
Sep 29, 2015 10:17 PM
