What intake manifold gasket should i get
Old Jan 12, 2020 | 06:37 PM
Jona91's Avatar
Default What intake manifold gasket should i get
Im replacing my stock heads for some 862 that are ported and was wondering on what intake manifold gasket i should get. There seems to be 2 different ones from what i can see.
https://www.rockauto.com/en/moreinfo...24102&jsn=9340
https://www.rockauto.com/en/moreinfo...24102&jsn=9342
Old Jan 12, 2020 | 08:50 PM
metalchip's Avatar
5 Year Member
Talking Felpro
Hello, check this out.
https://ls1tech.com/forums/generatio...-ms98016t.html
Old Jan 14, 2020 | 05:39 PM
00pooterSS's Avatar
Either works, I would use Felpro brand or OEM though. I've had trouble in the past with lower cost gaskets.
Old Jan 17, 2020 | 04:44 PM
chevymec's Avatar
I prefer Felpro or OEM that snap into the intake. Never used the type of the 2nd one you posted.
Old Jan 17, 2020 | 04:56 PM
00pooterSS's Avatar
Here at the shop we use both kinds and both are excellent. One snaps to the intake, the other type has little rings that locate on the head bolts near the intake ports. I don't have issues with either type. So one set you put on the intake then install it, the other type you put on the engine then install the intake.
If I remember right the snap on style (first link) are much cheaper though.
metalchip
Aug 16, 2019 12:52 AM
BlownHD
Dec 12, 2014 04:42 PM
Texfinn
17
Feb 14, 2014 08:19 PM
40series
Jan 4, 2011 04:42 PM
Hemi Killer
Feb 21, 2007 08:36 AM
