what is this fitting?
Old Sep 12, 2008 | 06:18 AM
sickREDsierra's Avatar
Default what is this fitting?
doing some work under the truck last night... i noticed a cast piece above the oil filter, looked like maybe a place where you could run a remote filter if you wanted to, like a relocator type piece..
anyway, it had a hole in the top of it, but i didnt feel any type of plug in that hole, i think it was just an open hole..
should that open hole have had a plug or anything in it? i dont remember it being threaded, although i couldnt get my finger all the way in it...
Old Sep 12, 2008 | 07:36 AM
hirdlej's Avatar
The piece that bolts onto the side of the oil pan there? That's where a remote oil cooler goes on the HD trucks or vans. If you don't have the remote oil cooler, then they just put a blockoff plate on (like you and I have) and if you feel above it, it feels like a hole but it's really just plugged. If you wantd to add an oil cooler, you'd take that block off plate off add the oil cooler assy. It's thermostatically controlled so oil is only allowed out of the engine when it gets too hot. InchUp should have the info on one as he added it to his GMC Sonoma.
Old Sep 12, 2008 | 07:39 AM
GMCtrk's Avatar
My 02LQ9 had the oil cooler lines.....we just stuck the block off plate from my 4.8 on there.
Old Sep 12, 2008 | 07:52 AM
nonnieselman's Avatar
Thats where the Turbo gets its oil from also.. You drill and tap where you felt the opening. put a adapter in there and run a line... Vola..
Old Sep 12, 2008 | 07:53 AM
i still have my 4.8 pan, but dont remember it having that piece on it.
guess i will have to pick up a block off or make one. not sure if oil is blowing out of it, or not?
i had a little oil on the bottom of the motor and trans pan, like it was coming from somewhere..
Old Sep 12, 2008 | 09:24 AM
kbracing96's Avatar
It's not actualy a block off, but a by pass. There is a cavity in the part that lets the oil flow from one port to the other.
Old Sep 12, 2008 | 01:49 PM
TurboGibbs's Avatar
As said above, there is no hole and nothing is wrong. Just bolt it on the new motor.
simman22
Jan 21, 2017 10:27 PM
FlowmasterMufflers
Nov 24, 2015 01:00 PM
SloSVO
Sep 12, 2015 06:56 PM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
LSX-81-SIERRA
Sep 5, 2015 02:51 PM
