What else?
Old Jan 23, 2010 | 06:03 PM
LowBlack99's Avatar
Default What else?
I picked up a LS6 intake awhile back and I have a F-body water pump so what else will I need to do the swap? I'm assuming F-body fuel rails and crossover? What about the TB? Going on a 99 5.3 with return style fuel system.
Is the gain worth the trouble or should I just sell the intake/water pump and stick with the truck intake?
Old Jan 23, 2010 | 06:18 PM
dirt track racer 81's Avatar
fbody alt and bracket, fbody powersteering pump and bracket, and tensioner
Old Jan 23, 2010 | 06:20 PM
LowBlack99's Avatar
Thats not required though? just looks better correct?
Old Jan 23, 2010 | 06:23 PM
are you using the relocation pulley? if not you need all the fbody accessories
Old Jan 23, 2010 | 06:26 PM
LowBlack99's Avatar
I'm still deciding if its worth it. Trying to find out besides what I have what else do I need?
Old Jan 23, 2010 | 06:51 PM
heres my 2000 with an ls1 intake, mallory fpr, ls1 injectors, ls1 fuel injector pigtails, aluminum fuel rails with steel braided lines. i cut up the stock rails and used some tube adaptors with an fittings that go back to the stock lines. it caught on fire a few days before this is the reason for the soot on the fire wall
Old Jan 23, 2010 | 06:58 PM
Bad Boyz Racing's Avatar
A Speartech idler pulley relocation bracket about $85.00, I used a water pump for a 07 NNBS think part # 12600767 about $150.00, it cleared my dirve by cable TB and a top raditaor hose off an 07 NNBS part # 19130027 about $52.00. I used the stock fuel rails off a 04 Z06, and an aftermarket fuel pressure regulator with a return line and car style injectors when we did my LS6 swap.
Old Jan 23, 2010 | 07:04 PM
Here's a picture with the water pump, fuel rails and injectors installed.
Old Jun 22, 2010 | 10:18 PM
bighoss77's Avatar
i really dont see too much difference between this and the truck intake, other than a bunch of mounting brakets and vac ports on the truck intake... does the ls1 intake flow better or something?
