What does lift do?....
Old Jul 11, 2005 | 05:54 PM
Tractionless's Avatar
Default What does lift do?....
What is the advantage and disadvantage of a low lift camshaft and a high lift camshaft?
pros and cons of XE grind?
pros and cons of XE high lift grind?
pros and cons of XE-R grind?
Which do you guys think is the most appropriate grind for a truck?
Old Jul 11, 2005 | 10:57 PM
C'mon guys.... someone must know about valve lift.
Old Jul 11, 2005 | 11:03 PM
02sierraz71_5.3's Avatar
Do a search it will net all the info you want over on ls1tech.
The more aggressive lobes open and close the valves quicker, they are a bunch of marketing Bull you pay more for a cam with those lobes than symmetrical ones plus they are alot harder on the valvetrain
higher lift means more air the valve is opened more
Old Jul 11, 2005 | 11:50 PM
goshawk23's Avatar
Truck addict
Talk to BigKID. imo he is the cam guru. I don't have the answers or i would gladly share.
Old Jul 12, 2005 | 12:33 AM
Flyer's Avatar
Originally Posted by 02sierraz71_5.3
they are a bunch of marketing Bull you pay more for a cam with those lobes than symmetrical ones.
All the gen3 sbc cams are the same price no matter what lobe design. Price varies from vender to vender, but they are all about the same.
Old Jul 12, 2005 | 09:32 AM
BLACKND's Avatar
Good Question, I have theories, but thats all they are at this point. I'd like to hear some good info on this also.
Old Jul 12, 2005 | 10:07 AM
zippy's Avatar
it's not a matter of not knowing what lift is. there is alot more to know about a camshaft than it's lift. that's why most won't answer.
Old Jul 12, 2005 | 10:45 AM
FILE's Avatar
You might find this usefull.
https://ls1tech.com/forums/showthread.php?t=327734
Old Jul 12, 2005 | 11:28 AM
Sport Side's Avatar
High lift usually is a good indication that your ramp speed is very aggressive. Meaning, your valve is going to pop open real quick like. Is this good? Depends.
Most camshafts set for n/a profiles use an aggressive intake lobe to pop the valve open quickly to where the head flow is substantially greater. Take a look at a head flow chart and you'll see why this is a good idea.
The exhaust is a different story. Once you crack it open the gases are drawn out quickly because it is pressurized. So, you can use a slower exhaust lobe with less net lift.
Simply put, on an N/A motor the intake air charge is not assisted. (Leaving wave dynamics of the air charge out for a moment). After the combustion stroke there is tremendous pressure in the cylinder. As soon as the exhaust valve cracks open it flows a LOT of air. It's basically boosted out of the cylinder if you want to look at it like this. Having the exhaust valve open too early not only costs heat (power) and velocity through the exhaust runners, it also empties the cylinder before the intake valve is open enough to take advantage of the pressure differential.
Old Jul 12, 2005 | 11:33 AM
white1's Avatar
Lift is just how far the rocker is pushed to open the valve, but the way it is applied, i.e. fast ramp/ slow ramp etc. has a lot more to do with it than just the amount of lift your cam has.
