What do you guys think of this cam for daily driver
#21
Tin Foil Hat Wearin' Fool
Originally Posted by TouchOfEvil04
No your right, it is way better.I don't start till 2600rpms but still alot stronger from there than it used to be.
But yeah the powerband really kicks in right at 3200rpms hard.
She breathes very well uptop as well making peak power at 5800 holding a damn near flat line till 6400 and only drops 11hp from peak at 6700.
Also I think he is worried about tq while cruising(aka tc locked going down the highway) I bet you have plenty of power without having to downshift with that combo.
#23
Seems anything larger would bring your lowend power down and give more mid range to high end power ?
#26
Thanks for posting it for me bro.
My self this cam works wonders for what i wanted it for.Once i get a 3200stall in it with the 8.1marine injectors and a retune.....shes gonna be screaming!!!!!
#27
formerly 1BADC10 (12/14/2011)
If he plans to keep the stock stall forever(given how he has modded I would assume a small one would be in the future) then 216/220 or the 218/220 would be my choice +2-4*s advance but Im no cam expert by any means just been doing alot of research on cam theories here lately.
*edit* Truck had 13s in it before I removed the cam... wish I took it to the track to prove before I removed it.
The reason I bought this cam was for the broad power range (1800 - 5500). I could spin the tires easily at 2K (gotta find a solution), and I have a PTC3000 hi-stall TC. I can tell you that as a DD, my truck is awesome. I went with a slightly larger cam b/c I do not drive it as much as I used to b/c my daily commute is pretty long (ricer is better on mpg's).
sauldgold
07-23-2015 02:15 PM
lxcoupe
07-21-2015 02:12 AM
