what cam would be good in a lifted z71
Old Jul 8, 2011 | 04:09 AM
Amedee's Avatar
Originally Posted by pewterliftedz
dood i bet that trucks feels like **** with 3.73s... i would add some 5.13s or 4.88s at minimum...then maybe a 2600 verter with a 212/218 cam..
^^^^^my exact thoughts^^^^^
Old Jul 8, 2011 | 07:32 AM
rjwz28's Avatar
Man Motor club
Start with a 4.88+, that will make up for the gear loss from the taller tires. Then investigate converters and cams to help you offset all that extra weight you're spinning. If you put 4.88s in your truck as it sits, your gearing will be slightly better than your truck on stock rubber and 3.73s. If you install 5.13s, your gear ratio will be the same as a factory tire with 4.10s. Just doing a gear swap by itself will improve the overall behavior of your rig, on and off the road.
Old Jul 8, 2011 | 01:57 PM
Nuclear Endless's Avatar
Gears , 2600-2800 converter and a 212/218 or similar cam should help out... 3.73s are killing you
Old Jul 8, 2011 | 05:20 PM
Beatdown Z's Avatar
Laid Back
Just regear to 4.88/5.13's. It would be plain silly to do any other performance mods before you regear it, imo.
Old Jul 8, 2011 | 05:44 PM
brandon_6667's Avatar
^this^
I run 315/75R16's (roughly 33's) and the 4.56 gear install made it faster than it was stock all the way through the rpm range and got me to right around stock cruising RPMS on the freeway
Old Jul 9, 2011 | 02:59 AM
rjwz28's Avatar
Man Motor club
/\ 315/75-16s are close to 35"(34.6) 285/75-16s are about 33"(32.8). Just FYI. I completely agree with Beatdown Z, and that's what I was trying to say too: the biggest key to restoring your truck's driveability is to rectify your massive gearing issue.
Old Jul 9, 2011 | 08:31 AM
1Bear's Avatar
Keep another thing in mind, even re-gearing to a perfect match in cruising rpm’s will not completely restore your trucks performance to stock, as you still have to overcome the massive weight and rolling resistance difference. I would bypass the 4.88’s and go for the 5.13’s as the other guy’s have already suggested.
Old Jul 9, 2011 | 09:08 AM
rjwz28's Avatar
Man Motor club
Old Jul 9, 2011 | 09:26 AM
bgray's Avatar
TOTM: June 2007
AS stated above by these guys, You are really doing yourself a injustice by using a stock 3.73. Not only is all that stress gonna snap your Tranny, but its a waste a time with 3.73. You need 4.88s for sure if your scared, with 39's id do 5.13's I had 4.56s on my 35's, and it rev matched perfect to stock.
Once you gear the truck, get a nice 208-212 cam, some 31# injectors and a good tune
Old Jul 9, 2011 | 04:57 PM
gdeen19's Avatar
Thanks for all the help guys. Gears first then I will worry about a can down the road. Sucks I got to change to sets LOL
