What Cam and heads?
Old Feb 19, 2011 | 12:12 PM
a4d's Avatar
a4d
Registered User
Default What Cam and heads?
Hey all I know this questions been tossed around alot just trying to figure out whats best for me. I want to get new heads and and a new cam just want to narrow it down there are so many choices I wantto keep it streetable of course a little shake wont be to bad I want to keep it a mild build and what kind ofHP #'s will I be looking at roughly of course? Thanks in advance
Old Feb 19, 2011 | 03:44 PM
chevyboy.520's Avatar
Your sig says Vmax, so I take it you have a 6.0. A TSP head cam package are great deals. You can pick your heads and cam for what you want. A set of porter ls6 heads to bump up compression. Or a set of ported 317's. Then you can choose a cam, alot of ppl say 228r is a mild cam for 6.0's. I'm sure more ppl will chime in too.
Old Feb 20, 2011 | 11:42 AM
a4d's Avatar
a4d
Registered User
Yes I have the 6.0 Sorry I should have mentioned that. Also since this is going to be a mild setup am I going to need to get a different stall converter? I don't know to much about modding street vehicles I usually do atv's or dirtbikes. thanks for anyhelp .
Old Feb 20, 2011 | 11:45 AM
AndysC3's Avatar
more than likely you will need a stall. If you go with around a 224 or 228 a 2800-3000 stall will get you going.
Do you tow alot? or is it just a DD?
Old Feb 20, 2011 | 02:03 PM
a4d's Avatar
a4d
Registered User
Pretty much like 90% DD like 10% tow if thatA few times a year we take the quads out to places like Michigan or WestVirginia but like i said mainlya daily driver
Old Feb 20, 2011 | 02:59 PM
I'd recommend headers aswell. You can get away with stock stall and gears, but if you really want full potential then they will be on your To-Do list.
Old Feb 20, 2011 | 03:13 PM
a4d's Avatar
a4d
Registered User
Ya I was planning on getting the heads and cam done first then bringing the truck to a place to have em just build me an exhaust. Is getting a custom system done reccomended or should I buy a full system from Magnaflowor whomever?Or buy headers and mufflers and then bring it to a shop and let them build around them.
Old Feb 20, 2011 | 03:56 PM
You can get headers with a y pipe, install them your self. Order which ever muffler you want, then have an exhaust shop finish it up. Or headers and tru duals, no y pipe.
Old Feb 20, 2011 | 04:42 PM
a4d's Avatar
a4d
Registered User
Is there a clamp I can use to hold it together or does it need to be welded im clueless
GrooveCityZ71
Aug 31, 2015 12:05 PM
JordanH
Aug 8, 2015 07:59 PM
steves86ta
Jul 28, 2015 10:21 AM
4B11T
Jul 13, 2015 03:48 PM
Aboss
Jul 9, 2015 10:28 AM
