What is the best way to achieve 15 to 1 CC?
Old Oct 10, 2006 | 10:05 PM
Stampede4ever's Avatar
Default What is the best way to achieve 15 to 1 CC?
Might run E85.
Thanks.
Old Oct 10, 2006 | 10:41 PM
old motorhead's Avatar
You're going to have to clarify your question a bit. If you're asking how to achieve a 15 to 1 compression ratio, I'd have to ask why you'd want that.
Old Oct 10, 2006 | 10:48 PM
dirt track racer 81's Avatar
to run that you would need more than e85..more like 114-118 octane or methanol
Old Oct 10, 2006 | 10:49 PM
02sierraz71_5.3's Avatar
110 is enough but E85 isnt its rated around 100. Best way to up compression is pistons, but if your having to ask then your not ready to build a motor like that.
Old Oct 10, 2006 | 11:11 PM
jakebdb56's Avatar
Old Oct 11, 2006 | 10:53 AM
I was wondering what the cheapest way to achieve higher CC. I thought about having the heads milled, but going that high of CC will cause other issues. Push rod length, intake milling, ect.. (Cost)
Also on E-85, I've heard it will run as high as 19 to 1 CC. I want to make sure. I was going to start low and work up. So I didn't want to put alot of money in project that might change. One thought I had was buy pistons for a 12 to 1 CC, then if I decided to increase CC, I would mill the heads, or use a thinner head gasket. Also thought about getting pistons for 13.5 to 1, and using a thicker head gasket to achieve the 12.
Has anyone or know of any who runs an E85 purpose built motor?
Thanks.
Old Oct 11, 2006 | 01:01 PM
i say do some more reading on ls1 style engines..
Old Oct 11, 2006 | 01:18 PM
Why? Is there something I'm missing? That LS1s have a compression ratio of 11.0 to 1.
Thanks.
Old Oct 11, 2006 | 03:09 PM
Zick's Avatar
Thanks.
Actually its only 10.1 on the 5.7 LS1. Lower on the trucks except for the H.O. Alum block 5.3 and LQ9 6.0.
Old Oct 11, 2006 | 04:09 PM
kbracing96's Avatar
E-85 has an octane rating of 105. That's good for about a 12, maybe 13 to 1 if the tune is right on. It's still got 15% gas in it. NO way you could run 19-1 that's diesel territory. Where are you getting your information from?
