weird stuff is happening
Old Aug 7, 2003 | 04:41 PM
Banned
Default weird stuff is happening
well, ever since the cam swap i've been throwing the missfire code, but red2k checked the codes for me a week or so ago and it was throwing a code about a THROTTLE POSITION SENSOR...anyways, i've noticed that every once in a while i'll be cruising at say 45 and put it to the floor and the RPMs will only jump maybe 500-1000 instead of downshifting and hauling *** like it should and use to do. it doesn't always do this, just maybe once a day. it does seem to do it when the heat has had time to build in the motor from say sitting at a red light(remember it's been 100 the last 10ish days here) and when i leave the light it barely wants to move at all and if i floor it, it wont even spin the tires over, and other times it will just hook up and haul ***. what's up here? are the insanely high intake air temps causing this??? i thought it could be pulling timing or something of that nature but i'm not to keen on all that part of the performance yet. any clues??
Old Aug 7, 2003 | 05:22 PM
L82gofast's Avatar
Default Re: weird stuff is happening
Its hotter than a snakes *** down here also. The IAT could be pulling timing with how hot it is. You might want to tap into the TPS and check your voltage over the range of closed to WOT. If it threw a code it must have seen something funny with the TPS. Just a thought....
Old Aug 7, 2003 | 05:26 PM
David Cairns's Avatar
Got this from Autotaps mailing list. Have you considered that it might really be the throttle position sensor, just like the code says?
Mike Fahrion back again with this week's topic for fellow shade-tree mechanics. Today's topic is a wear-out prone mechanical device called the Throttle Position Sensor (TPS).
When I was studying electrical engineering, I took a couple mechanical engineering courses since that field always interested me too. My mechanical engineering professor loved to quip "Electrical devices are inherently unreliable, mechanical devices are inherently reliable." I took a lot of verbal abuse when I tried to argue that the opposite was true (and I don't think I helped my grade any either). I submit today's email as supporting evidence for my opinion!
Even though today's vehicles are fuel injected, they still have a throttle plate that is controlled by your right foot. That's what controls how much air flows into the engine's intake manifold. As you push harder on the accelerator, the throttle plate opens further. The TPS is attached to that throttle plate and its electrical resistance goes up as a contact within the sensor slides over an increased length of wire.
Using three wires (power, ground and output) the vehicle's computer sends a voltage through that variable resistor and measures its output. Using that information (and a bunch of other stuff), the computer knows how heavy your right foot is and decides how much fuel to inject.
As you might guess that sensor can wear out (after all, it's a mechanical device in my book). Or, it can get corroded or dirty. Then what happens? The voltage it puts out either gets "stuck" or it gets jumpy and the voltage bounces up or down as you press the gas pedal. Any of this leaves the computer pretty confused. One symptom is engine hesitation when you try to accelerate. It will often (but not always) set the check engine light. Typical trouble codes are P0120 P0121, P0122 and P0123.
So - how do you tell if it's bad? I love this one - you can make the diagnosis from the drivers seat while listening to your favorite radio station. Plug in AutoTap or another scantool that supports real-time data, and read the Throttle Position Sensor voltage with the key on, engine off. I suggest using the "Graph-It" feature of AutoTap to be sure you don't miss anything (jobslike this one make graphing an invaluable feature!). Now, slowly press the accelerator to the floor. You should see a smooth line on your PC or Palm. It should start down around 0.5 volts and rise to around 4.5 volts (exact values depend on the vehicle). If the line is bouncing down to 0 or up to 5, the sensor's bad. If it's stuck at a constant value, the sensor's bad.
This is an easy sensor to replace. You'll find it attached to the side of the throttle body (conveniently located at the top of the engine!). There's a wiring harness and a couple screws to remove - that's it!
Note that some throttle position sensors require a simple adjustment once they're installed. This usually involves installing it loosely and checking its voltage in the idle position.
There is a newer type of TPS that no longer uses wear-prone mechanical contacts. The new style uses a magnetic field to generate the signal. I don't know what vehicles use the newer type of sensor but it seems like a good idea.
Happy Repairs,
Mike Fahrion
www.autotap.com
Old Aug 7, 2003 | 11:56 PM
Banned
TTT for me and RED2K
Old Aug 8, 2003 | 02:57 AM
Flyer's Avatar
Those things are really hot???
David .. that was gonna be my suggestion too.
Old Aug 8, 2003 | 12:49 PM
Banned
guess i'll call Moritz and see if i can get one cheap. ANYONE ELSE HAD THIS PROBLEM???
Old Aug 8, 2003 | 01:15 PM
GREGGO's Avatar
Great info David! I think I'll put a copy of that over in the tech links thread for future referance.
Old Aug 8, 2003 | 01:22 PM
Scream's Avatar
MOOBIES Moderator
I have the SAME problem, and it started with the cam swap. The truck "short shifts" from a stop and won't downshift automatically. It will downshift manually, however.
I ATAP'd my truck and got a code for the TPS and also for the MAP sensor, along with my normal misfire code.
I replaced the TPS, the truck ran smooth and had no problems, then started doing the same damned thing again.
Is there a cure??? I just thought that I was going to have to live with this forever.
Old Aug 8, 2003 | 01:24 PM
Scream's Avatar
MOOBIES Moderator
Is it possible that something with the cam swap is messing up the TPS? Is that even possible??
Old Aug 8, 2003 | 03:48 PM
Banned
i'm gonna go pick one up here in a few minutes since i have to go pick up some tags for my mom's truck there anyways....i'll post a part number and price when i get back with it.
