Weird feeling in pedal..
I'll try and explain this but i know its there and i had a friend of mine feel it to. Pretty much everytime i turn off the truck and let it sit and go to start and driveaway right before it ends first gear it has like a Vibration or rubbing feeling go through the gas pedal. Like maybe a solnoid or something? It doesnt do it everytime i stop but jsut after the truck is off.
Originally Posted by unklej
It's perfectly normal. Around 10 mph the ABS system does a system check and runs the pump.
Jeff
Jeff
nope.... I think the recall has to do with the hydro boost brake assist. I don't have it, not sure if you do though. That vribration is from the abs check.
I could be wrong (correct me if I am) but I think the hydro boost unit uses the power steering pump to transfer hydraulic fluid to the master cylinder area to aid in brake assist. I don't have any such setup. I have the normal vaccum booster.
Jeff
Jeff
dantheman1540
14
Sep 28, 2015 09:22 PM
