this was weird
Old Aug 1, 2005 | 09:53 PM
Kano's Avatar
Default this was weird
I was at the track a couple of weekends ago
and made my run
@1/4 tank of gas
well about the end of the run
I heard it cutout at about 5400
while all the bad thoughts were running thru my head as to what happened
I heard a dinging noise and got the "hey dumbass you need gas" light
eased on around and stopped and the gas gauge was a little over 1/4
my thinking is that it pushed the fuel to the back and sucked up some air
anyone else seen this
Old Aug 1, 2005 | 10:09 PM
shandy294's Avatar
Haven't seen that...isn't the pick-up always submerged?
Old Aug 1, 2005 | 10:16 PM
Kano's Avatar
dont know
but what would cause the cuttin out?
and the out of gas light?
FWIW It hasnt done it again with a full tank
Old Aug 1, 2005 | 10:26 PM
shandy294's Avatar
Maybe someone has seen it and will post...good luck!
Old Aug 1, 2005 | 10:29 PM
SSlow 4.8's Avatar
wow, that is weird. Maybe your gas gauge is off?
Old Aug 1, 2005 | 10:44 PM
Kano's Avatar
hope so
thanks
Old Aug 1, 2005 | 11:26 PM
NeverSatisfied02's Avatar
My buddies truck did that but he had a little less than a 1/4 tank. It probably was just the fact that the gas was pushed to the rear of the tank and it sucked up some air. Especially if the gas light came on, im sure the sensor in the tank is probably in the front also. That would make sense. I wouldnt worry about it unless it happens again.
Old Aug 1, 2005 | 11:57 PM
Kano's Avatar
I think Ill keep at least a half tank when I go to the track from now on
Old Aug 2, 2005 | 05:59 AM
JERRY2500's Avatar
14 Second Truck Club
Been there done that. It will run lean when you get below a 1/4 tank. Mine does the same thing.
Old Aug 2, 2005 | 04:44 PM
Seeing Red Again's Avatar
It must be nice pulling enough g's off the light to cause fuel starvation!
I want to have that problem when I grow up.......
