weight reduction tips
Old Jun 8, 2007 | 06:51 PM
ridndirty's Avatar
Default weight reduction tips
what did all of you do for weight reduction? what is easiest/fastest? just wondering what all of you are doing
Old Jun 8, 2007 | 07:02 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Jenny Craig.
You knew that was coming, didn't ya?
Try removing the loose stuff, spare, jack, etc.
Old Jun 8, 2007 | 07:05 PM
The fastest/easiest weight reduction is to remove the spare tire and jack.One of the most effective is to go with light weight wheels and tires,which effectively reduces drivetrain weight and actually improves rear wheel horsepower.
Old Jun 8, 2007 | 08:01 PM
kbracing96's Avatar
Don't forget the tailgate.
Old Jun 8, 2007 | 08:04 PM
ridndirty's Avatar
done that what else?!
Old Jun 8, 2007 | 08:06 PM
2004SSS's Avatar
well if you want to go all out you can remove your passenger seat and if your ex cab or cc you can remove the rear seat. i may do this before i hti the track.
Old Jun 8, 2007 | 10:29 PM
Lurius's Avatar
I usually remove sub box, rear seat, misc. tools and equipment in the back seat, I dont have a spare, or spare tire equipment.. no jack, etc.. Then I remove the back seat(ext cab) inner door panels(plastic interior panel). I imagine its a goo 2-3 hundred pounds overall.. I get the vehicle down to 4800lbs w/o driver this way.. I also have a fiberglass tonneau, 10lb nitrous bottle(like 26lbs full?), and 20's on(old wheels weighed 45lbs+32lb tires.. new ones are more like 28lbs each+32lb tire, so a little lighter now even.)...
-Lurius
Miguel199
Oct 16, 2015 08:04 PM
97_ek
Sep 23, 2015 09:16 PM
2500ZL1
Sep 12, 2015 03:50 PM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
