Vvt cam question... Sort of!!!
Old Mar 26, 2016 | 04:28 PM
Wolftrk99's Avatar
Default Vvt cam question... Sort of!!!
Been planning my l96 build and lately have been toying with the idea of adding vvt to the yukon, question is would an ls3 cam work with a vvt setup??? Looking at ls3 specs vs the vvt cams comp cams has they are somewhat similar... Biggest difference being the lsa! Any insight would be great.....
Old Mar 26, 2016 | 11:52 PM
Vortec350ss's Avatar
I guess it probably could work if the loves were installed on the proper center lines and you used the phaser limiter. It's a wider LSA with shorter duration than a lot of VVT cams.
Old Mar 27, 2016 | 12:10 AM
Wolftrk99's Avatar
Just thinking ive already got an ls3 cam, and dont wnat to buy another, if it will work with vvt theoretically it should give me some better low end i would hope....
Old Mar 27, 2016 | 02:40 AM
07NBSChevy's Avatar
I would definitely use a Phaser Limiter kit but it should work.
Old Mar 28, 2016 | 10:49 PM
Wolftrk99's Avatar
Got to check tomorrow, but i don believe the ls3 cam has the oil feed for the cam actuator in the 2nd journal so i dont think it will work....
Old Mar 29, 2016 | 02:30 PM
Wolftrk99's Avatar
Well it was a good idea,but the ls3 cam wouldnt feed the cam actuator... So there is no way it would work
01SilveradoJakee
11
May 30, 2016 09:17 AM
Jake75
May 3, 2016 08:26 PM
booboo37
Mar 4, 2016 07:54 PM
Chevyssr1997
Mar 2, 2016 11:46 AM
09CamdSilvy
Mar 2, 2016 09:47 AM
