Votec manifold
Old May 25, 2005 | 08:48 AM
Default Votec manifold
Has anyone tried to modifiy the stock TBI manifold (90-95) to fit the vortec heads. I read that it can be done, but don't know the specifics.
If not, is there another choice other than the GM ($309.00) manifold?
Old May 25, 2005 | 11:58 AM
kbracing96's Avatar
I hade a friend that drilled and taped a set of vortec heads so a old style small block manifold would fit on them. It was kind of a pain. This was back when they first started using them on circle track cars and no one was making carb manifolds for them yet. They mocked them up on a old block and set the intake on it and marked the holes and then made a jig to hold the head in the drill press and then drilled and taped them. It is also kind of difficult to get the runners to seal, because the vortec runners are taller then the older style heads and intake manifolds.
Edelbrock makes a Performer manifold that bolts to Vortec heads for $165 but it has a carb flange on it. You would need to make, or buy a adapter to put the TBI on it.
Old May 25, 2005 | 04:02 PM
Thanks KB96
I think that would be too much of a pain, and it definitly isn't worth sacrificing dependability.
I think that the adapter was my next question. Edelbrock makes some good manifolds like the performer for a good price. I wonder if anyone makes one of the adapters that would work and NOT take away from the performance
Old May 25, 2005 | 08:44 PM
kbracing96's Avatar
http://store.summitracing.com/defaul...part=HLY-17-45
There you go, Don't think it would hurt performance any.
Old May 25, 2005 | 10:20 PM
litreddevil's Avatar
Banned
I am in the works of doing the same the rpm preformer is what iam going with and the tb to carb spacer plate.
Old May 26, 2005 | 05:36 AM
Thanks guys, That's exactly what I'm looking for. Now I just need to find a good deal on a intake and I'll be set
LittleD. What cam are yo going with?
OHsixLS3
Nov 22, 2015 07:45 PM
turbo6c3
Oct 5, 2015 06:11 PM
JordanH
Oct 3, 2015 03:59 PM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
