Vinci Ultra Torque vs Comp Xtreme Hi-Lift
Maybe we are talking about two different "types of overlap. I'm talking intake opening to exhaust closing, if you look at the graph, you can see the 48 that Vinci lists on their website and teh 38 Comp told me today seems to make sense. Maybe you are talking about overlap on each side of TDC? I've seen this negative overlap mentioned before, but honestly never took the time to understand what it was? I also updated the picture to show the 5* of advanve vinci puts in their cam, but I could install the comp with that as well, right?
(intake duration+exhaust duration)/2-(LSAx2)=overlap @.50 but the calculation would be the same for .50 specs or .006 specs
another calculation is
(intake duration+exhaust duration)/4-LSA=overlap
5* advance is a lot, at least in my opinion. Most of comp's off the shelf grinds have 4* advance in them which I think is a lot depending on the size of the cam. If your stuck on a off the shelf cam then go with the tr220 on a 114 lsa. I think that cam might even pass smog untuned
Originally Posted by TBSS
If you're putting this much effort and thought into a cam I don't understand why you wouldn't want a custom grind.
Hey, I hear ya. I've done plenty of reading and understand how the factors affect the operating range of the cam. i.e. to keep low end/ mid range torque you want to close your intake sooner rather than later and keep your overlap from getting out of hand. I understand how changing those parameters changes things, but am not sure how incremental changes will have an impact. What if I advance everything 4 degrees and widen my LSA 2 degrees. Thinks like that I woudln't know the impact. I know what I want my next house to look like, but I can't say that I'd know how to engineer/design it. I dunno, I'd love to do it just not sure I would be helping or hurting myself.
the 6.0's must be different because I wouldnt even look at a cam over 216 in size if you werent getting a stall. I had a 210/218 and mine lagged downlow TUNED untill I got a stall. I wouldnt even think of the 220/220 I have no on a stock stall
These cams dont start making power untill 2800-3000 rpms, and I dont see a stock stall working with that combo off the line
if you are keeping a stock stall, then go with the 212/218 but its gonna need tuning also
I could say get a 224/224 like everyone else, but I dont see that working with what you want
